Question about Panasonic Televison & Video
Radk screen when you look at the tv from below or different angle the screen is dark
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 124 Answers
If tv is old increase bright service mode setting or increase screen control in eht
Posted on Apr 29, 2014
How to replace a bulb
Depending on the type of TV the backlight will usually be either LED or CCFL. If the backlight is the only fault then the TV will still have sound and a bright light from a torch shone at an angle onto the screen should show a faint picture. Repair of the backlight is not a simple task and could be a number of different causes. LEDs are unlikely to fail in such a way as to blank the whole screen. CCFL tubes can cause the whole screen to go dark but replacement is very difficult. I would recommend getting a TV repair engineer to fix it.
Mar 14, 2016 | Televison & Video
When viewing from below tv the screen is dark
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Mar 27, 2014 | Panasonic Televison & Video
When i turn on my ispymphony 32 inch nothing comes on
The fluorescent ballast has taken the proverbial dump. Take a light and look at the screen closely from different angles. See if the menu from the remote is in the darkness of the screen. If so, your backlight went out, or at least the capacitors that fire it. Get a new unit unless you know electronic repair.
Nov 16, 2013 | iSymphony LC32IH60 TV
Approximately 2/3 of the screen is dark. this started about six months ago and is progressively becoming worse. when problem began the screen would recover to full brightness after it was on for 30...
Hi there...it is sounding like a backlight is going/has gone out...these can be proffesionally replacedat a repair shop...To self diagnose if it is the backlight take a flashlight and, with tv on and while on a tv channel and carefully form different angles look into the 'dark' part of the tv screen...if the/a backlight on a lcd tv/monitor goes out(even laptop screens) then u can still see a faint image with a flashlight(or without one with a good eye)....If you still see the (tv channel) image, then it is most likely a bad backlight......
I hope this helped you some, if it did(or not) please rate!...Thank you
Apr 16, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TO GET THE DIFFRENT BETWEEN LCD VS PLASMA
LCD
LCD stands for liquid crystal display. These types of displays have been around for awhile and are commonly used with computers. One reason for their big popularity is the ability to produces a better picture than CRT monitors but also being much thinner.
Pro’s
  • Low Energy Consumption – LCD monitors use very low amounts of power. This is why it is very commonly used in battery powered devices.
  • LCD screens also reduce the amount of glare on the screen which can be very beneficial if your TV is in a room with lots of light.
  • If an image is left on the screen too long, LCD screens are less likely to experience the image being burned into the screen. If this does occur, it’s easier to repair than other types of TV’s.
Con’s
  • The viewing angle of an LCD TV is typically not as great as Plasma but the difference is not great enough to make a huge difference.
  • LCD TV’s can sometimes get dead pixels which aren’t typically covered under warranty. Although they are very small, they can become very annoying.
  • Brightness levels aren’t as great as Plasma and it’s not possible to display darks quite as dark.
Plasma
Plasma technology hasn’t been as widely used as LCD in previous years but has become very popular in large HDTV’s. Although they have historically been more expensive than LCD TV’s, they are becoming more comparable in price.
Pro’s
  • Brightness and color are the major advantages of Plasma TV’s. They produce rich colors along with very deep blacks.
  • Their wide viewing angles allow more people to be able to watch TV comfortably.
  • The pixels of Plasma TV’s are lit individually unlike LCD screens. Because of this feature, the pixels can be completely turned off to display truck black colors.
Con’s
  • The lifespan of a Plasma TV is typically shorter than other types of TV’s. The lifespan can be extended by turning down the brightness of the screen.
  • Plasma TV’s are more susceptible to screen burn-in where an image is “burnt” onto the screen when left on the screen too long such as a network logo in the bottom right corner of the screen.
  • Plasma TV’s require a panel of glass to cover it. This glass can reflect light and make it difficult to see the picture. If placed in a dark room, this typically isn’t an issue.
Jun 09, 2009 | LG Televison & Video
Dark area on screen
Try moving different devices away from the tv, there may be some type of interference.
Hopefully it's not your TV going bad...
May 25, 2009 | Dynex DX-LCD32-09 LCD TV
No picture will talk, picture dark
If you mean you have nothing on the screen, either the backlight or its associated power supply has faiiled. Look at the screen at several different angles; if you can see some sign of motion, then the LCD panel itself is still ok.
Nov 06, 2008 | Sansui LCDVD200 20 in. TV/DVD Combo
Dark screen on TV
This sounds like a speaker got too close to the TV.
Degauss is built into many tv's check for it in the menu.
Otherwise, yes a TV shop or yourself will need to degauss the TV.
May 14, 2008 | Televison & Video
LG 26LC55 32inch LCD
yes all lcd's, for that matter tv's have viewing angles ..What you are experienceing is normal
Mar 04, 2008 | LG 32LX1 32 in. HD-Ready LCD Television
Hitachi 57F500, Dark areas
Hitachi dark problems at ctechnicians.com
Dec 27, 2007 | Hitachi 57F500 57" Rear Projection...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
