Question about Sony Xplod Cdx-gt700hd In Car Audio Stereo Cd/ipod/mp3/wma Player Receiver Usb
I have a sony head unit works excellent but when i turn on the cabin fan stereo shuts off then when i turn fan off stereo comes back on with no loss of stations
Installed in a mazda t3500 bus
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
Use a different outlet for the reciver
Posted on Apr 04, 2014
Cdx-705
Most cd changes only work with like brands. Sony with Sony .jvc with jvc. Find a manual for a brand new model on google or the the manufacturer and see if it has a problems section
Dec 27, 2013 | Sony Cdx-705 10-disc Intensified Shock...
After market stereo works with key in acc. Does not work with engine running. There is power 14.0+ V in both the continuous power wire(yellow) and acc power wire when started (red) going into head unit....
Most, if not all cars will shut off accessory power when cranking so that the starter has plenty of current.
If your stereo doesn't come back on again once the car is running, that's a different story... is it a cheap and nasty unit?
Nov 03, 2013 | Car Audio & Video
LG Air Conditioner LST182V-4
It may cause it to shut down if it's a safety thing, but it sounds like the compressor's faulty to me.
May 16, 2012 | LG Heating & Cooling
The entire unit will not come on. I changed the battery thing that was it. It was not what could it be?
Have you checked all the connections, especially the "remote" turn on from the stereo? This wire is usually a small gauge "blue" wire coming from your head unit. When you turn on the head unit it will remotely power on the amp.
Sep 24, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Fan on outdoor a/c unit not running
call in the technicians
compressor shutting down or power to the fan being interrupted causing the compressor to shut down
Jan 23, 2018 | Goodman CKL36AR36 Air Conditioner
2004 chyrsler pacifica front fan stops on high
Replace the resistor in the front fan system.
Nov 12, 2017 | 2004 Chrysler Pacifica
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Stereo turned off going over bumpy road
if the radio completely shut off chances are that there is lose connection somewhere. If the radi0 (head unit) will not turn off take out the radio and check to make sure there is a secure connection on the yellow and red wires. Also check to make sure a fuse was not blown due to a short.
If an amp will not turn on check the blue or blue/white wire for a secure connection and also check the connections at the amp. Ensure none of the power connections to the amp have come loose.
Oct 28, 2009 | Kenwood Car Audio & Video
The fan on my 2004 SAAB 93 convertible will not shut off.
I would suspect that the cooling fan relay ( in a relay / fuse box under the hood) is stuck. There are 2, a high and low speed relay. Pull one and see if the fan goes off. Once you have identified the culprit, see if there is an identical relay in another location that you can swap into place to verify the problem is fixed.
Mar 24, 2009 | 2001 Saab 9-3
Speaker issues
Disconnect whatever wire is connected to the blue wire behind your head unit. Re-connect it to the blue/white wire, instead.
Jun 21, 2007 | Sony CDX-M770 CD Player
Sony Xplod Cdx-gt700hd In Car Audio Stereo Cd/ipod/mp3/wma Player Receiver Usb Logo
53 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
