Question about Philips GoGear HDD6330 MP3 Player
30GB how to fix my go gear 30gb if it keeps saying connect to pc every time i hook it up to my pc it does nothing the computer chimes but the mp3 players does nothing help me pleassee!!!!!!!!!!!
  • Anonymous Nov 09, 2007
    Every time I switch on the mp3 it tells me to connect t to PC.I conect and absolutely nothing happens, cant even open the mp3 on the computer's hard drive. it is not connecting at all.
Perhaps you still have it in "hold" position.
Otherwise, reinstall the software or try to put music on by adding the folders direct into the Phillips with the explorer.
Posted on Nov 04, 2007
Zune 30gb says "Connect Zune to your PC" and when
Hi if you have done this 7 times the HD is bad and will need to be replaced. I fun into this all the time with the Zune players.
If you need more help, parts or repair services you can go to my repair service web page at firehouse7777.weebly.com and find info to contact me if needed. thanks
Dec 11, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I have the 30gb gogear mp3 player and while I was syncing it it malfunctioned...now my computer says it doe'snt recognize it and that it malfunctioned and it's screen shows that it is connected to the...
Connect your player to the pc that has the Philips device manager running, then reset the player by holding the off-switch and the volume-+ (plus) switch.
If it will still not start as it should, repeat the reset, and as soon as the player shuts off, press and hold the volume- - (minus) switch. The Philips device manager will recognize the player now, and recommend a repair, do so.
Jul 13, 2009 | Philips GoGear HDD6330 MP3 Player
Won't turn on
If your Dell Computer is running Windows Vista, it will not work with the Philips HDD series Go Gear.
If it is running Windows XP:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 31, 2009 | Philips GoGear HDD075/17 MP3 Player
Phillips 30gb will connect to computer but wont sync anything
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
-Tha Mp3 Doctor
Feb 26, 2009 | Philips GoGear HDD6330 MP3 Player
My computer isn't detecting my Sansa mp3 player anymore.
First, make sure the lock switch isn't engaged.
Try this: disconnect the player from the computer, turn it off, hold in the volume + (or Record) button, and reconnect the player to the computer while holding the volume + (or Record) button in. Keep holding the volume + (or Record) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start --> Control Panel-->System--> Hardware--> Device Manager (you computer may vary slightly, depending on Windows Version).
-Tha Mp3 Doctor
Oct 28, 2008 | SanDisk Sansa c200 MP3 Player
Ipod 30gb black
Hold down the middle and menu buttons at the same time for about 10 seconds. this will restart the ipod.
hope this helps and good lcuk!
Jaxon
Oct 03, 2008 | Apple iPod MA446LL/A MP3 Player
Philips sa920017
Triple Reset for Philips’ GoGear:
-Tha Mp3 Doctor
Jul 14, 2008 | Philips SA920017 MP3 Player
My philips go gear keeps saying please connect player to the PC but when i hook it up to the computer it does nothing may i please have some help
hold volume + button plug the device to the computer (while holding the volume + button) a window should pop up about 5-30 sec later.
Jul 01, 2008 | Philips GOGEAR SA6045 MP3 Player
Go gear wont hold charge
There is a program that came with the installation Cd called Philips Device Manager. You can download it from www.usasupport.philips.com if you lost the CD. Use the Philips Device Manager to repair the player. If the device manager will not repair the player, then try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
May 17, 2008 | Philips GoGear HDD6330 MP3 Player
30gb zune install
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 21, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
63 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
