Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
New external harddisk cant be detected on my computer
I just bought a new external harddisk 250gb. i tried on my computer, it cant be detected. while it can be detected on my friend's computer. i tried alot different method, it still don't works.
is there any solve to it ?
  • 1,555 Answers
Since you have not given any specifications about model of your HDD hence I'd consider your HDD connects through USB. Your USB driver is old you shall consider upgradation.
Posted on Jun 15, 2009
Mybook WD25001032-001 keeps on flashing and won't work...what is wrong with it. I need help. Thanks
Try plugging the usb cable on a different port on the computer. If the light flashing is red, then there is a hardware problem on your WD. If this is still under warranty, then its best to have it checked from where you bought it or to any authorized WD service center. If its no longer under warranty, then you can open the WD and check for any disconnection. The inside contains a harddisk; you may want to disconnect the two connectors from the harddisk and reconnect them again.
Mar 25, 2011 | Western Digital 250GB MyBook External USB...
This drive 250gb hitachi is not being recongnised by my computer.
maybe its in the bios settings that set to first boot was your external hdd,,,open bios settings and set first boot to harddisk drive,to boot your primary hdd so your external will be now detect
Feb 12, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
External hard drive won't connect to computer
first of all you should try it on deferent pc , if its ok then thatleads us to insufficient power provided through usb ports , try usingback usb ports not the ON-front, and if the problem still try usingdual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.htmland if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changedif you cant find a similar one you may buy a new empty cage
Mar 22, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
Harddisk not detected by system
Do you see the drive light on and can you hear the fan on your disk? If yes then try using a different usb port and a different usb cable. Check to see if there are any other drives with the same drive letter.
You can find this by right mouse clicking my computer, select manage, select disk drive manager see if the drive is recognized and if it trying to use the same letter as another. If so change the letter and it will be seen.
Mar 13, 2010 | Western Digital 250GB MyBook External USB...
Computer Not Detecting External Hard Drive
Try a new cable this may work if not it sounds like the HDD has failed you can try placing the drive in a zip lock bag and but it in the fridge overnight then try again if this fails then its U/S.
Mar 08, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
I've dropped my Western Digital 250gb hard drive & now its not working. The light on the device does light up & the computer recognises that something has been connected but you cannot see the...
I've similar problem with Samantha_500, i inadvertently dropped internal Harddisk (Seagate 80GB) with external case (M-Tech), the external case was broken into pieces (only the parts with plastic), the Harddisk is not working anymore, it detects by windows XP as a device connected in USB, but no drives detected in windows explorer. is there any way to recover this harddisk? thanks for the help in advance.
Dec 26, 2009 | Western Digital Passport WDXML800UE...
I pluged in my external Simpletech 250GB and no drive is detected. I had only used a few times when I bought it. It was detected when I first open from the box. Now, it doesnt detect in any of my 3...
Have you checked your CMOS settings to see if the BIOS is enabled & it can see your drive ?
Usually get there by tapping Del key during inital power up of computer.
Sep 28, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
250gb Maxtor External HardDisk not responding
How are you connecting it to your pc?  are you supplying external power?
Jan 01, 2009 | Maxtor Hard Drive
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer fails to recognise my external hard drive
I would suggest the external casing of the harddisk that contains its power supply is busted, so you need to change the casing or remive the harddisk from the casing and connect in inside
Feb 16, 2008 | Western Digital Caviar WD2500BB 250 GB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
313 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
