Question about Sylvania 6427FF TV
I Would Like to Change my Aspect Ratio
Playing on my xbox 360, some of the screen is cut off. I have tried everything I could in my xbox settings to stop this, but there is always at least a little. I am not using HD I'm using composite. Is it possible to change the TVs aspect ratio?
    Top Expert:
  • Sylvania Master
  • 73,698 Answers
Yes. It is possible. Refer its user manual for details. If you haven't the user manual to this set, http://www.manualslib.com/manual/510730/Sylvania-6427ff.html
Try the above link to download it in PDF. Gopakumar Gopalan Google
Posted on Mar 28, 2014
I have an old tube tv screen, 19 inch. Fable 3 just does not seem to want to fit properly. I am missing about an inch on all sides. I am pretty sure my xbox settings are right.
Most 360 games are made for High Definition Widescreen now.
Have you got an aspect ratio button on your remote? Try switching it to 16:9, and changing your Xbox settings to "Widescreen". You may get the two black strips top and bottom, but the game should look fine. I hope this works for you, as I know how annoying that can be!
Jan 26, 2011 | Microsoft Fable 2 for Xbox 360
Cannot change aspect ratio when im playing a game it cuts off part of the screen
Normal aspect ratio is 4:3, and the wide aspect ratio is 16:9. If you play a game meant for 4:3 and you change the TVs aspect ratio to 16:9; part of the picture will be cut off. It is not the fault of the TV.
Oct 15, 2010 | Sanyo DS27800 27" TV
Aspect Ratio is off
east west correction cirket is faulty change/check releated components near the horizentle yoke connection
May 23, 2010 | Quasar SP-2725 27" TV
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Edges of picture being cut off LG 37LG30 LCD TV
Yes, it is possible the settings from your cable box maybe set to the wrong ratio eg:letterbox. Depending on what type of box you have, look in the cable box menu for a settings option, then change the aspect ratio to a different format.
Jun 30, 2009 | LG 37LG30 37 in. LCD HDTV
The bottom and top of the picture are being cut off
Check your remote for a "zoom" or "picture size" button. Press this button to adjust the size until everything fits back on the screen.
Please take a moment to rate this solution a fixya if it's helped with your problem. Thanks for asking here!
Mar 21, 2009 | Vizio L32 32 in. LCD HDTV
Sanyo HT30744 Aspect Ratio Help
Do you still have the original remote? If so there is a button that says "Pix shape" that will change your aspect ratio for you. If you are watching something in HD it should say "full". If it is analog it will say "normal" in 4x3 format. If you want it stretch hit it till it says "zoom 1" or "zoom 2". If you don't have the original remote I am not sure how you would change it. You can find them on ebay if you need one. Hope this helps.
Jan 30, 2009 | Sanyo HT30744 TV
Xbox picture gets cut off on the sides
try fiddling with the tv menu. most tvs have the zoom function now and also the ratio function. try testing those configurations starting from the default. make sure you have the zoom function set at 0 before fiddling with the ratio aspect.
Aug 14, 2008 | Samsung TX-R3075WH 30" TV
Screen resolution
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Dec 26, 2007 | Microsoft Xbox 360 Console
Xbox 360 stretched screen out and cannot fix it now
Have you checked the aspect ratio?? May be that when the kids had the X-Box hooked up they simply changed the aspect to zoom.
May 22, 2007 | Sanyo DS20425 20" TV
Sylvania 6427FF TV Logo
172 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
