Question about Akai LCT3201AD 32 in. LCD Television
KEYBOARD LOCK NO RESPONSE
IT DOESN'T WORK OR RESPONSE EITHER FOR THE BUTTON OF THE TV OR THE REMOTE
    Genius:
  • 1,003 Answers
Sounds like a bad main control board
Posted on Mar 28, 2014
The remote doesn't work for any of the DVD functions.
1 replace the old batteries use new ones alkalines with the same mark and polarities.
2) clean the contacts batteries with c. cleaner.
3) open the remote control, and clean the keypads from dirty, oxide, corrosion, with c. cleaner.
4 Proceed again, if the problem persist, you must go to the repair shop TV or replace by new ones.
God bless you
Nov 11, 2012 | Televison & Video
Controls not working onDaytek TV, 40 in LCD,
yes, look carefully in the manual as I think it has a lock out feature that will lock out both keyboard on set and remote except for on off features.
Jun 13, 2012 | Televison & Video
My UN40D6400 remote doesn't work
look carefully in the manual to see if it has a lock out where all or most buttons do not work--also the remote can be tested--every button--testers are common and also a digital camera in a dark room will react when remote is pointed at it and buttons pressed--flash on camera screen--either the remote or likely the set has it locked out in some way.
Apr 24, 2012 | Samsung 40 UN40D6400 3D LCD TV
I accidently locked my TV. I have no idea what the code is. When I switch on the TV there is a blue screen with lock written on it. The remote control is CHUNGHOP RM-441e Universal PLZ do help. The Whole...
Hello
You can unlock the FPA lock of your RCA TV. But, you must ahve its original remote control to perform the proceedings. if you haven't it original remote cntrol with you now, just try to buy a new one, of just borrow it from any of your friends or relatives who owns the same model Tv.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
One amoung the above process will surely unlock your RCA TV. OK.
Sep 20, 2011 | RCA TruFlat 27F520T 27" TV
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
My 32 in 2011 smart tv has aproblem. the lg apps will not initialise and the home screen locks up. then there is no response from remote at all. i turn the tv off and on then it works but if i try to go to...
I have the exact same problem, it started straight after the last os update. If u try entering the home screen right after turning the tv on it will allow u to enter but the apps won't initialize and the tv will lock up in the home screen as soon as u press any button on the remote apart from the back button. I have no idea what is causing it but if anyone out there has any idea of the cause or even better a solution can u please let us know.
Aug 27, 2011 | LG Televison & Video
Front panel locked and remote don't work
To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Mar 22, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Television Model # WD-52627, Serial # 107108 - TV Not Responsive
This model is equipped with a keyboard lock feature. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Aug 18, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Akai LCT3201AD 32 in. LCD Television Logo
18 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
