Retrieve data from drive
How do I retrieve data from the drive. A manual available.
  • 3,320 Answers
What drive? What computer?
What OS?
What?
Posted on Mar 28, 2014
Can I retrieve data from a non-working hard drive?
There are people who can retrieve data from dead hard drives but it can be costly so get quotes first-- look in the phone book
other than that the data is long gone
Feb 10, 2016 | Power Computers & Internet
How can I retrieve data on a dropped/malfunctioned seagate portable expansion drive?
Not a DIY task. You need a professional with data recovery skills. There are few good ones around.
Jul 07, 2014 | Seagate Expansion 1.5 TB USB 2.0 Portable...
Retrieve Hard Drive Data External Hard Drive
click start right click on my computer you should see your drive select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors then select check now
start should schedule this task when restart if this is the hard drive with your operating system on it
i have found the best results ticking one box and wait until its finished then return and tick the other box
do not do anything while the chkdsk utility is in progress any input may damage your computer
also
there are many freeware data recovery programs available on the internet and many pay data recovery programs
http://download.cnet.com/easeus-data-recovery-wizard/3000-2248_4-75184619.html
http://download.cnet.com/pandora-recovery/3000-2094_4-10694796.html
Mar 26, 2012 | Computers & Internet
I have been using this Transcend FlashDrive 4Gb data stick for more than 2 years. Suddenly my computer refuses to recognize it. I tried in other computers too, but to no avail. How do I go about...
Try to find an IT Technician and ask them to use data recovery software eg. "Ontrack Easy Recovery Professional" to recover the drive.
If this solution fails then it likely that the data stick electronic components have completely failed.
Aug 24, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Retrieving data from dead hard drive
Retrieving data fromdamaged hard disk is possible. There are companies that can remove the diskplatters from the damaged hard drive and with special equipment may beable to recover your data, but it will cost you an arm and a leg for theirservices. The reason for this high cost, they dismantle and remove the plattersin the hard drive in a clean room environment and set up the platters up injig/drive to retrieve/copy the data. First thing I would try isto remove the damaged hard drive and connect it to an USB hard drive adapterand then plug this adapter into a working computer's USB port. If thiscomputer sees this hard drive as an external hard drive and you can open thevarious folders and files, then I would backup your data. If the hard drive is notdetected then the hard drive is dead and data cannot be retrieved with thismethod.
Aug 14, 2011 | Computers & Internet
I have a w.d. external HD all my files is gone, so how can i get it again? but if i check the propeties the used space is it there.. so how can get back again?
To recover your WD files, please follow the below steps:
First thing first - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Jun 05, 2011 | Western Digital WD Passport 250GB Portable...
Need to format flash drive, but want to keep data
try 2 get a software caller get data back. format your flashdrive and retrieve back the data using that software. software is readily available on torrent site just download it. t.y.
Jan 31, 2009 | Computers & Internet
Hard drive shuts off after 10 seconds
There are a variety of things that can malfunction on your external hard drive:
1) The cable
2) The external hard drive casing
3)  The hard drive itself
If you have tried plugging in your hard drive to different computers and are still having the same issue, then there is either a problem with your casing or with the hard drive itself, because you've already switched out cables.
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computerstore, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The GigaBank 320 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period.
For specific warranty and replacement information, go to www.iomagic.com  and click on Support.
Have a nice day,
I/O Magic Technical Support
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Iomagic
Have you looked both in Device Manager and in Disk Management?
Have you tried plugging your external hard drive into another computer?
If it isn't recognized on multiple computers, then you are probably experiencing a hardware failure.
1) The USB cable - Have you tried switching the USB cable?
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on our website.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within the warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
Jun 15, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Where
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
May 14, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
