I HAVE DELL 5330N PRINTER ON THE DISPLAY KEEP SHOWING FUSER DOOR OPEN
WHAT IS THE PROBLEM?
    Top Expert:
  • Computers & ... Master
  • 25,302 Answers
Door interlock either faulty or not closed properly.
Posted on Mar 27, 2014
How do I replace the fuser in a dell 1350cnw?
First, Be Careful, the fuser is normally very hot. Unplug the Printer power cord whenever you are opening it up to do anything, except change the toner cartridge.
1 Push the rear cover release handle and open the rear cover.
2 Lift up the fuser release levers (2 blue Handles behind the rear Door)
3 Lift the Fuser up and out.
to re-install, just do the reverse
Mar 02, 2015 | Dell Office Equipment & Supplies
Reset fuser reading in window display what should I do
Open the fuser door and pull the fuser unit out, top of printer or top rear. Should see 2 oval looking handles I believe they are blue, grab the handles and pull the fuser should pull straight out. Then re-seat it back in to printer. And by the way do this procedure while the unit is sill turned on.
Jul 31, 2012 | Dell 2130cn Laser Printer
What is "fuser door open"
Fuser Door Open is the message on the display when it's powered on. I took the back apart, removed the fuser, looked all over. I couldn't see any kind of sensor, optical or mechanical that makes when the door is closed. There's an access plate with a blue latch below the fuser that makes an optical sensor and a mechanical sensor, but that seemed to be OK. It didn't seem like something that would be called a fuser door. So, I pushed on it where it made the mechanical switch and the printer hummed to life and the message went away. I took the fuser out and examined it. The metal brackets where the pivot parts were, seemed a little bent. I straightened them out, stuck it back in and that fixed it.
By moe who hasDell MFP 1850DN this might also help...
or Fuser Door Open
1. Make Sure the Paper Tray is Loaded Correctly With no Obstructions
2. Clear the Paper Jam in Tray 1 or 2
3. Clear the Paper Jam in the Multi-purpose Tray
Jul 05, 2011 | Dell 1815dn All-In-One Laser Printer
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
The fuser door is stating it is open when it is closed I have turned off and taken out fuser turned on and then replaced. still showing fuser door is open will not print or copy
That is a problem with the fuser door switch which is a part of the High voltage power supply. Replacing the HVPS should fix this right up.
Apr 28, 2011 | Dell 1815dn All-In-One Laser Printer
Display say fuser door open. what is this
Hey, make sure the rear door is shut, if it is, you most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS.
Oct 11, 2009 | Dell 1815dn All-In-One Laser Printer
Fuser door open on dell 1815n
If you have tried closing the fuser door (rear door) several times and the error continues. You most likely need to replace the High Voltage Power Supply (Part# WH773). Iteminc.com has this part and can ship same day. The sensor which reads if the door is open can go bad and it is part of the HVPS. Good luck!
Oct 02, 2009 | Dell 1815dn All-In-One Laser Printer
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Message shows "fuser door open"
There is a part called the "fuser" inside of the printer. Its purpose is to heat up and melt the toner to the paper. Fuser may need to be replaced, need to call printer tech. Fuser is extremely hot, 300 degrees to melt toner. Recommend call printer tech to fix.
Don't forget to rate this solution.
Jan 14, 2009 | Dell 1815dn All-In-One Laser Printer
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
