Question about Pool & Spa
Hot tub stuck in PR mode.
My hot tub is stuck in PR mode. I have tried resetting at breaker, draining and letting sit a few days disconnected but still can not get out of PR mode. Can you suggest a resolution?
  • 1,631 Answers
Very simple...
Pr is only a brief "timeout" upon powering up the hot tub control system. Pr means - "Priming" Mode. That's it!
it will be in this mode for about 6 minutes.
Then system will revert to normal operation mode.
If if it doesn't start up and start moving water, you may have an airlock in the main pump. Remove the airlock: 1st turn power off, then by closing any discharge side isolation valve, usually found immediately after the heater.and then opening the highest union nut. Usually found on discharge side of the pump or entering the heater. You will hear air hissing, and then water squirting out. Allow the water to continue to squirt out for approximately five seconds. Then tighten the nut, and then open the closed valve, if you closed one.
now turn the power back on, and try again.
Good luck.
Posted on Apr 11, 2015
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 64 Answers
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Posted on Apr 13, 2014
djxtreme979
  • 151 Answers
SOURCE: 115 volt 20 amp breaker for hot tub keeps tripping
Is there anything else on the same breaker? Is that the proper amperage for the pump? How long has the pump been in service? It may need to be cleaned as possible obstruction causing too much strain.
Posted on Dec 28, 2008
zeusfaber
  • 247 Answers
SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
Posted on May 25, 2009
SOURCE: Running a 220 volt 40amp service for my hot tub.
By code, this would require underground cable to a breaker panel with a double pole GFI (maybe that's what you were planning). Then from the breaker panel to outlets, pumps, etc.
40 amp breaker will require 8 AWG cable.
More info, let me know...
Charlie
Posted on Aug 23, 2009
Testimonial: "BY CODE, means it's the law!!! I didn't want to cut thru my black-top driveway. It's about 130 feet around the yard to the hot tub."
Coastsider
  • 331 Answers
SOURCE: hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Posted on Apr 14, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: hot tub pump flo-master hp suddenly wont start.
The fault is most likely to be the condensor. They can and do fail at an early age.
You don't need to dismantle the pump, on the rear of the pump you'll find a slot on the motor shaft which can be turned with a screwdriver.
If you've only just reffiled the hot tub it could also be an airlock.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 20, 2010
My hot tub works for about 20 mins and clicks the GFI off. Then I reset the GFI and the spa comes on for about 7 mns and trips the GFI again. Is this my heater doing this?
Easy way to test for the heater issue is to disconnect the heater from the board. Disconnect both leads from board and let the spa call for heat. There is also a chance the GFI breaker is bad however most times the heater fails and the breaker is doing its job.
Apr 01, 2017 | Hot Tub Works Pool & Spa
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
I recently switched some breaker around in my fuse box. There were a few 110's and 220's not being used. I deleted those to make some room to put a larger amp breaker for my hot tub that been sitting
Try for what ?
You removed breakers not needed or ones with little
on them, to make room for a larger 50 amp Hot Tub
Breaker,so you got your hot tub powered up
What is the question,seems you solved the issue
by making room for the new breaker !
Nov 21, 2014 | Electrical Supplies
Great lakes hot tub
Hi, I am not a hot tub expert and I don't know what PR status is or what PL on the display means . However I did a quick search for you and have a web address that might help you find a solution.
http://www.spacare.com/troubleshootingguideforspaandhottubs.aspx
Hope it helps you
Regards
Steve
Mar 27, 2014 | Garden
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
I am getting a Pr code and the tub is not coming on at all
If the unit won't start, make sure power is on at the electrical outletor the electrical panel Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
I cant get my hot tub outof sleep mode
Try turning your GFCI breaker off then back on, may reset the tub's computer. Works on some.
Aug 18, 2012 | Dynasty Leisure Bay Dynasty Spas
240 w/60 a outside breaker with test switch wont'
Inside the controller box is a red button to reset it but most likely the heater element is shorted out so replace the heater element first. Cost $100.00 at any pool or spa shop. Post here if you need more help.
Sep 28, 2009 | Siemens 12 Q115u 15a Circuit Breaker, Qp
Pool & Spa Logo
506 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
