Question about Ovens
I have a creda cooker c367gwh when you turn the oven on it makes a lot of clicking noise
  • 20 Answers
The clicking noise is probably ignitor, seek gas engineer to fix
warmest regards
Richard The Repairman
Posted on Mar 31, 2014
beekeeper42
SOURCE: creda fan cooker
The switch that controls the power to the oven is triggered when the oven door is closed. As I recall, it is associated with the quadrant hinge on the right side. Over time, the switch collects grease and residue and gets balky. It is easy enough to clean, but requires the oven side (inside) of the door be taken off. If you are at all handy, it is not a problem. While you are there you will likely find that you will want to clean out all the other grungy memories of past feasts. When I cleaned ours it worked as good as new. Good luck.
Posted on Feb 19, 2009
barkencoa
  • 3463 Answers
SOURCE: top oven on creda electric cooker working but
Even though you have continuity trhrough the element, it could still be faulty, to be sure if the element is o/k or not, you need to check if it is getting 240 volts to it.
If it is, and it is not getting hot, then you need to replace it.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
barkencoa
  • 3463 Answers
SOURCE: can not reset clock or timer, oven will not work
Try pressing the first 2 buttons on the left, and the last button on the right of the timer all at the same time.
It may differ to this depending on the actual model, but it is usually a combination of 2 or 3 buttons.
Hope this helps, if it does solve the prob, please feedback.
Thankyou.
Posted on Dec 21, 2009
  • 40 Answers
SOURCE: creda cf50g cooker oven not getting hot
sounds like the ffd is at fault, this is a safety device that alows the main flow of gas through. when the cooker is cleaned the sensor can be moved by accident from its position over the flame, another reason could be a build up of grease etc, stopping the flame reaching the sensor. if none of these then the ffd unit needs to be replaced. they are about £20.00 for the part
Posted on Apr 07, 2010
blackmar
  • 235 Answers
SOURCE: Creda Concept Solarglo Cooker. Grill
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Posted on Feb 12, 2011
Testimonial: "Many thanks for the prompt reply. I'll follow up your recommendation!"
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
My creda cooker lost power when I turned on the grill but did not trip the main fuse and there is still power at the main swtch
Is it a built-in model? If it is then there is sometimes a wall plug in a cupboard that may have a fuse in it.
Feb 01, 2016 | Creda Ovens
Creda problems
Hi, if there is no regulation on the hob, it is typically the switch that is faulty unless halogen, then it could be the thermal cutout.
warmest regards
Richard The Repairman Colchester Oven Cooker Washing machine repair
Mar 30, 2014 | Creda Ovens
De dietrich range cooker very noisy when oven on?
Have you checked the exhaust fans within the oven? These can make a lot of noise if something has come lose. They should be located at the top of your oven or on the back. I would check that.
Good luck
Dec 05, 2013 | De Dietrich Ovens
I didnt get a user manual with my creda cooker dont know how to set the timer
try this site for your manual
kitchen.manualsonline.com/manuals/.../creda/creda_oven_product_list.html
hope this helps
Apr 28, 2010 | Ovens
Creda cf50g cooker oven not getting hot
Apr 06, 2010 | Ovens
Creda Solar Plus Model 48339N Clock/Timer not working
You have to remove the complete top assy as one unit. To do this you need to remove the side panels, there are screws at the rear, and some at the front of the oven, you will then be able to see the screws securing the top
The top then slides towards the rear, then you can gain access to the timer unit.
Hope this helps.
Dec 08, 2009 | Creda Ovens
How to change an oven lamp in a creda concept oven
Hi
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email gary.connell@talk21.com
Cheers
Aug 09, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
