Question about Home
Great Lakes 2005 Hot tub
It is stuck in PR mode. I have tried resetting at breaker, emptying and leaving sit disconnected, refilling....nothing will get the PR screen to change. It is stuck in this mode. Do you know how to resolve this problem?
  • 717 Answers
This is usually a PR code meaning "Priming" and only shows up when the spa is filled and the power has just been turned on. The purge cycle typically lasts about 3-4 minutes.
How long does it stay on the PR mode?
Rod
US Parts Center
Posted on Apr 08, 2014
Great lakes maniste hot tub comes on click like breaker tripping in tub, could it have bad fuse in tub itself?
Does the breaker trip instantly or does it take a minute? If there is a delay i would start with checking heating element. Instant is a direct short, try unplugging all components and if still trips then check wiring and breakers. If power stays on with components unplugged, plug them back in one at a time to see which one causes failure.
Feb 22, 2017 | Pool & Spa
No power, great lakes hot tub hear click like breaker tripping,down below in hot tub could it have bad internal fuses?
Charles, sorry I just re-read your question. The click you hear is likely a contactor if its an older model, and if it clicks its probably not the problem, just means its getting voltage. I would start by looking at the high limit switch. Look for a little reset button. A high limit switch trips when it senses high temperature, often from heater trying to run with Inadequate water flow.
My great lakes hot tub pump is on low speed and it will not shut off. I have it set to Ec mode.
One of two things either the thermostat is bad or the relay that controls the pump motor is stuck
May 27, 2016 | Pool & Spa
Hot tub stuck in PR mode.
Are the pumps primed, the code represents that the pumps are being primed and should only stay on 2 - 5 minutes. If the pumps are not primed then you may have an air lock or dirty filters. You need to release the air or clean or replace the filters and your pumps will prime.
Mar 27, 2014 | Pool & Spa
Great lakes hot tub
Hi, I am not a hot tub expert and I don't know what PR status is or what PL on the display means . However I did a quick search for you and have a web address that might help you find a solution.
http://www.spacare.com/troubleshootingguideforspaandhottubs.aspx
Hope it helps you
Regards
Steve
Mar 27, 2014 | Garden
My hot tub is not coming on at all and is giving me a Pr code. What can I do?
please follow this steps and fix it. God bless you
If the unit won't start, make sure power is on at the electrical panel or the electrical panel . Then test the pump and the motor. Check for and repair broken wires or loose or corroded terminals. If necessary, have the pump switch control tested and serviced professionally.
If the jets do not work, clear a blocked water intake of hair and other particles (see below) or replace a broken jet (see below).
If the water in your spa or hot tub is too hot or too cold, check to see if the high-limit reset switch has been tripped and, if needed, reset it. Adjust the thermostat setting and have the thermostat serviced if the problem persists. If necessary, test and replace a faulty heating elements
Nov 26, 2013 | Qca Spas Dream Series Dream Master Hot Tub...
Reset error code hot tub
tub is in sleep mode usually to change u must press temp button then light button you want to b on standard mode STD
Oct 04, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
I have a Great Lakes spa hot tub and nothing turns on, setting was saying OH. We turned the breaker off and then back on and now it is saying 5n.
OH MEANS OVER HEAT AND THE 5N WHICH IS ACTUALLY SN IS YOUR SENSOR SO IT WOULD NEED TO BE REPLACED SO YOULL NEED TO CALL A POOL AND SPA COMPANY FOR EXAMPLE..... HOTSTUFF SPAS&POOLS SALEM,OR
Sep 29, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
