Question about Ematic EGQ307 7" 8 GB Wi-Fi Black Tablet Android 4.2, LCD Touchscreen, 1024x600
Tablet turned off but won't turn back on
I checked the battery while using it...had 60 percent left or more. went black and I cannot get it to turn on. I tried pushing the reset button on the back (little picture of 2 arrows in a circle...you use a pen or pin to press it)still nothing working. I tried charging, just a black screen. had it since Dec. 23rd 2013.
If I used .129 gigabites of 2 gigabite plan, how much do I have left?
Ah. Now, I can answer.
You have 1.871 gigs left, or 1871 megs left. You've used about 7 percent of your space.
Feb 23, 2016 | Samsung 32GB Galaxy Note Pro 12.2" Tablet...
How do I fix my tablet that won't fully charge?
Your tablet may need its battery calibrating. To do this run your tablet until it turns itself off, this will ensure that there is no charge left in the battery. Then leave it on charge until the battery is full. Normal battery use on modern devices like tablets and phones should be between 25-75%, with a calibration once every 3-6 months to ensure a good battery lifespan. If this solution does not work you may need to replace the battery.
Jul 07, 2014 | Visual Land Connect 9" Android Tablet...
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
http://www.pandigital.net/userfiles/file/Downloads/QSG_%20PRD07T-1_v2.2_09-08-10.pdf
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Ematic EGQ307 7" 8 GB Wi-Fi Black Tablet Android 4.2, LCD Touchscreen, 1024x600 Logo
42 people viewed this question
Top Ematic Tablets & eReaders Experts
Ap12
Ap12
Michael Harrier
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
