Question about Keurig Vue Brewing System
Water leaking not just comming out of spout
Asks like is plugged water comes out on all sides of the water spout including the water spout
    Problem Solver:
  • 14 Answers
Sounds like your water outlet is clogged. Open the head and push up the cup holder to remove. When out, clean out the tube at the bottom of the holder with a paper clip or something similar (I use a cake tester - long skinny metal rod. This will clean out any clogs in the output path. Also remove the bottom part of the cup holder and clean it too. Put back together and place back in brew head the way it came out. (Caution - some models you have to twist the cup holder to remove, and some it just comes straight out). There are many you-tube videos that will show you this also.
Posted on Apr 20, 2014
Water leaks between the pull down spout and the bathroom tile
It sounds like your spout supply nipple has sprung a leak. There isn't much of any other way water can flow between your spout and tile wall. It's pretty important that you don't use the fixture until the problem is fixed. Because the water coming out that you see is also probably flowing into the wall and causing water damage and MOLD. You need to remove the spout and replace the nipple that is supplying the water to the spout. There could be a defect in your spout too, but likelihood of that is less than your nipple threads giving in to some electrolysis from the bronze/copper in the spout or somewhere in your water system. To prevent it from occurring again, use a brass nipple to replace the galvanized nipple in it now. Red brass, no yellow brass. Good luck with your problem and always know where and how to turn your water off to your house before attempting a plumbing repair.. Most spouts screw off. Counter clockwise, use a pair of channel locks by inserting the rubber coated handle into the opening on the spout then using the leverage of the channel locks to unscrew the spout off of the wall. It is not a repair that requires to have the water off to your home before attempting to repair. It only emits water when the tub valve is turned on. If it doesn't unscrew, twist it until the under side is up and you will see a slot where you can insert an allen wrench to loosen it and then slide off. Inspect the spout while it is in your hands to see if it is damaged of if the nipple sticking out is damaged. one of the two must be, because water flowing from behind the spout is definitely not normal and definitely something you need to fix right away, before your wall and floor behind your tub are damaged or start to grow mold.
May 04, 2014 | Delta Faucet Delta RP17453 Pull-Down...
I replaced an Moen spout for my shower unit. Water flows thru the Spout and when level is pulled water flows thru the shower head. But there is water leak somewhere (reverse flow?). The ceiling below it...
if you have copper piping,you probably twisted the pipe when,you tightened the spout ,and broke pipe. If you are'nt able to get into the wall on the shower side, cut a hole on the other side of shower wall to repair it.
Aug 04, 2011 | Garden
I have a Kenmore side x side. I have changed the water filter and now water is coming from the water spout when water is needed to make ice. Just prior to changing the filter I noticed water coming from...
Sounds like the dual water inlet valve on the back where the water supply is connected, has gone bad and is leaking across to the other side. It may also put water into the ice maker when you use your dispenser.
Jan 13, 2011 | Kenmore 44103 Side by Side Refrigerator
PASSENGER SIDE FLOORBOARD FILLS WITH WATER WHEN IT RAINS. COULD IT BE A CLOGGED CABIN AIR FILTER? OR SOME SORT OF DRAIN PROBLEM SOMEWHERE ELSE LIKE THE A/C?
this sounds like a clogged drain like you said. look underneath the vehicle on the passenger side for a little black rubber drain spout. if you park under trees alot, it is very common for these to plug up. when you locate it, have the a/c on for about 15 minutes so that there is condensation for it to drain. if there is nothing coming out, take a coat hanger and insert it into the spout and pull the junk out. do it until water comes out.
Jan 24, 2010 | Oldsmobile Intrigue Cars & Trucks
My admiral leaks as soon as the water turns on, it appears to be coming out of the housing unit for the hoses rather then the tub or the hoses.
There are a few places that a washer could be leaking:
1) the water valve itself, it may be cracked (most are plastic), or the hose connecting it to the spout may be loose.
2) the hose from the water valve to the spout (as above) could be loose from spout or water valve. It also may be cracked or have a cut in it from wear on other parts.
3) the spout may be damaged or loose from the back plate making it misaligned so the water spills over the side of the tub.
4) the washtub may be missing a spring that keeps it centered in the machine causing the fill spout to spray water over the side of the washtub.
5) There may be a leak in the tub, pump, hoses for the pump (not likely since when it leaks)
That's all that there is to leak when it does not leak all the time. (if it were all the time you could throw the supply hoses and valves in the mix.
Hope that helps
Oct 31, 2009 | Admiral AW22 Top Load Washer
Leaking unit
check to ensure that the drain hose is not touching the side if the water storage bin. if still no luck then watch unit when running to assess the leak point............maybe a hairline crack in water container
Oct 30, 2009 | Heating & Cooling
I'm getting water coming out of the seam on the left side between the top of the washer and the side panel. Is this hard or expensive to repair?
If the washer leaks all the time, check these:
  • Water inlet valve: If water drips even when the washer is off,check the water inlet valve. It is located inside the washer at the back of the unit. The fill hoses are attached to it. Replace if deemed necessary.
  • Water fill hoses: Check the water hoses from the household plumbing. Tighten it or replace it as necessary..
  • Main tub seal: It is located between the transmission and the outer tub. To see the leak, fill the machine with water with small amount of detergent then open up the machine's main access panel.. The leak appears at the underside of the outer tub, at or near the center. The seal is difficult to replace and you probably should call a qualified appliance repair technician.
  • Pump: You can spot the leak when the tub is full of water if the pump leaks. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. Replace it as necessary if it leaks.
  • Outer tub: The outer tub can rust, split, or be punctured.You may have to replace the entire tub but its not economical repair to do. Consult a qualified technician for deatils.
If the washer leaks only during the fill cycle, check these:
  1. Air-gap device: It is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It is located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. It is usually made of translucent plastic. If one of the air-gap components deforms or cracks, you have to replace it.
  2. The tube: It is a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  3. Inlet spout: It is a plastic spout found on most washers near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
Oct 24, 2009 | Maytag Washing Machines
Jura Impresso E9 not dripping through spouts but into drip tray
This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
Mike
Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Water dispenser
limed up at end of spout/ clean lime out with small screw driver or somthing small to get in end of spout/ once lime is clean water will come out normal
Aug 05, 2007 | Frigidaire Gallery Series GLHS269ZDB 36"...
Keurig Vue Brewing System Logo
200 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
