Question about GE Refrigerators
MY GE REFRIGERATOR TBXW25FLM HAS WATER IN THE BOTTOM CONSTANTLY
I EMPTY THE WATER AND IT REFILLS IN A DAY
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
Is this in the bottom of the fridge? if so check the drain the goes from inside the fridge threw the case out the back sounds like sonthing is stuck in there. just pull everything out and have a look at the back of the fridge ( might have to pull a few screws out to check it)
Posted on May 22, 2014
  • 65 Answers
SOURCE: Water Leaking from the bottom of the Refrigerator
is the floor of the freezer a sheet of ice? if so the defrost drain hole is clogged.
Posted on Feb 16, 2008
  • 12 Answers
SOURCE: GE Bottom refrigerator/MOdel GS18LCRABB
I can only wonder if the drain tube has been cleaned out to make sure water flows into the pan .Also make sure it is fully defrosted and left over water will freeze quick.
Eeggman
Posted on Mar 10, 2008
SOURCE: Water in bottom of Roper Refrigerator/Freezer Unit
I have the same problem. I suspect the drain line for the auto defrost is clogged and so the water is dripping down into the fridge. (The water from the auto defrost cycle is supposed to drain into a pan under the fridge where it evaporates over a period of a few days). I have yet to locate the drain line though.
Posted on Mar 31, 2008
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
mgprice
  • 744 Answers
SOURCE: water leaking out of the bottom of my ge
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Sep 11, 2009
Ge profile side by side model pye22kskbss is not making ice.
Is the icemaker getting water into tray? If not>refill valve is ng
Is there ice in the tray? If so, heater element is ng and that needs replacement.
Or just get a new icemaker on the cheap at site. eBayeBay
Sep 09, 2017 | GE Refrigerators
Water in tank continuously slowly flows out. No flapper but a central tower.
What ever functions as a flapper is defective and needs to be replaced.
Nov 10, 2014 | Home
Water Ridge dual flush toilet issue!!
Of course ALL the DIY centers (Lowes, Home Depot, Ace Hardware, Do-It-Best, etc.) sell toilet repair kits. Sounds like you need a flapper replaced in your toilet. Search online for toilet flapper replacement to get guide on DIY.
Nov 10, 2014 | Home
O have a GE Fridge Model GFSS6KKxass i am having a issue with water accumilatimg under the both crisper drawers not sure what is causing this?
My GE Fridge did the same and the repair man I called said there is a little drain hose that goes from the top to the bottom of the Fridge at the rear see if that hose is plugged. I unfastened it at the top and blew air through it and the water is no longer a problem.
Jul 19, 2014 | GE Refrigerators
Why does my water container fill up even though my machine is plumbed in?
This looks like a fault. The plastic tank has two reed switches that measure 'tank empty' and 'tank half full'. When the tank is empty the inlet solenoids (there are 2 for safety) open and water enters the tank but not so much to fill the tank to the half way level. In normal operation the level water in the tank will drop and then more water is allowed in. In your case it appears the 'half full' reed switch is being activated because the solenoids are not closing off properly and water is leaking in and filling the tank. If you do not empty it then eventually it will fill and leak into the leak. The problem can be caused by either low water pressure (below 145 psi) or sticky solenoid. If is the solenoid then the Miele solution will be to replace both solenoids. Alternately you may be able to remove, take apart and clean. Also check that you have a mesh filter at connection to tap. Also you can temporarily fix the problem by turning off the water at the tap and re-programming machine to 'turn off' the plumed water line. regards
May 31, 2014 | Miele Coffee System
GE Fridge water dispenser working but not the ice
Yes you most likely have a defective dual water control valve. Look around the inside of the refrigerator for a model number.
Click here=> For most locationsSide-By-Side
  • Top Freezer
  • Bottom Freezer
    Once you find the model number I will be able to tell you what part number the dual dual water control valve is or if your ice maker assist you in testing ice maker. If ice Maker is empty try filling with tap water to top edges of ice maker, allow water to freeze and if the ice drops into the ice bin but does not refill with water automatically I would say that the dual water control valve will need replaced. If your ice maker has old shrinking ice from a few days ago it will point to an ice maker problem.
    Thanks, Sea Breeze
  • Feb 10, 2012 | GE Refrigerators
    After machine has finished cycle and is not used for a day water refills in drum although its empty and door open
    This is symptomatic of an intermittent (hot, if it's both hot and cold fill, cold if it's cold fill only) water control valve. Its physical no power/fail position is closed but yours is not closing completely. It needs replacing so sorry, service call ;-0(
    Good luck,
    John C
    Mar 17, 2011 | Zanussi Washing Machines
    My new K-4632 AA toilet flushes fine and refills the bowl. The tank equipment works as it should. Problem is, the bowl completely empties in about 5 minutes and stays empty until the next flush. The...
    Hello. Your toilet is leaking through the flush valve. This is a serious issue as it will use a huge amount of water every day. Check to be sure there is not an obstruction in the tank and if you can not find one, call the plumber. J.
    Oct 12, 2010 | Kohler Home
    Refrigerators Logo
    102 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
