Question about 1992 Ford Ranger Distributor Rotor for V6 3.0L 8th Vin Digit U
92 ford ranger fuel pump runs constantly
Fuel pump runs constantly
    Sergeant:
  • 361 Answers
I think they stay on all the time the key is on anyhow , you may just be noticing the noise now because the motor on the pump itself is going bad , that is the only reason I can think of
Posted on Mar 29, 2014
Not start after sitting
Try turning the key just to on. Listen for the fuel pump to run and quit. try this 2 or 3 times then attempt to start . if this works it may indicate a leak in the fuel system. Hope this helps
Dec 30, 2013 | Ford Cars & Trucks
1988 ford ranger fuel pumps both come on for 2 seconds and go off.\r\nevery time i turn the key this happens. can i wire the pumps to a hot wire whenever the key is on they will run?
the pumps should run for a couple of seconds then shut off when the regulator determines the fuel pressure is correct. If you wire it, it will probably shorten the life of the regulator since pressure will constantly be applied to the regulator.
Apr 18, 2011 | 1988 Ford Ranger
Put a new fuel pump on my 92 ranger. 3.0 l 2wd, itll crank and you kan hear the pump run but wnt fire, any ideas?
your question is to vague.
what made you change the fuel pump. (symptoms)
Always remember an engine needs
  1. fuel
  2. spark
  3. compression
  4. timing
have you confirmed that you are getting fuel and if are
check for spark
and work down the list if one is missing that's your answer
Jan 20, 2011 | 1992 Ford Ranger
1999 ford ranger V6 truck cutting out or missing real bad when I try to excellerate
if it runs fine at idle and at constant speeds, I would start by changing the fuel filter, if that doesn't correct the problem. check the fuel pressure and see if it the pump going oout
Jun 14, 2010 | 1999 Ford Ranger SuperCab
I have replaced the fuel pump on this 92 Ford Ranger. I put a fuel pressure gauge on the truck. It will idle for about 20 seconds with the pressure running between 70 and 80 psi. After a few seconds, the...
The mechanic should check on the idle .Because the Idle of the truck is adjusting by it self . That causes the truck to stop .check the Idle then lock it up to so that it will not adjust until it will make the truck stop .the main reason why the truck stop and pressure guage going down steadily is that no fuel enters the fuel pump when it adjust Idle by it self . It adjust by closing way or blocking the fuel to pass and go to the engine.then the engine dies .
Aug 22, 2009 | 1992 Ford Ranger
Fuel pump wont come on
bad ground wire? worst case you can run your own swicth to the pump but this woud be run off the ignition so the key must be on . is it in your tank or exturnal on the frame of the truck?
Jun 16, 2009 | 1992 Ford Ranger
Will not stay running
put a pump back into the tank --and this will take care of the fuel delivery problem
Jan 05, 2009 | 1992 Ford Ranger
No fuel
You may have put the filter on backwards. If you did I might have ruined the fuel pump. Whether or not you did, test the wires that run to the pump. If they are getting power, you need to replace the pump. If not, start checking fuses and relays.
Dec 14, 2008 | 1992 Ford Ranger
92 ford ranger
replace fuel pump. replaced fuel filter.check relay switch,fuel cutoff switch... any ideas.
Jun 11, 2008 | 1992 Ford Ranger
1992 Ford Ranger Distributor Rotor for V6 3.0L 8th Vin Digit U Logo
79 people viewed this question
Top 1A Auto Parts Vehicle Parts & Accessories Experts
Jesse Walters
Jesse Walters
george parkes
Are you a 1A Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
