Question about Frigidaire Ovens
Figidaire my effortless oven door will not closed
  • nancy
    nancy Mar 29, 2014
    I took the bottom rack out and was able to close the oven door
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Nancy, this is JK. I see that you were having some issues with your door closing due to the racks but were able to correct this. Please reconnect with us if you do need any further assistance. Best Regards,
Posted on Apr 16, 2014
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Display shows door not closed for self cleaning when door is closed
think it means lock door . there might be a sliding lever between the cooktop and oven door slide it to the right .
Feb 20, 2015 | GE JKP20 Electric Single Oven
Oven door doesnt close well
I'm not familiar with your oven but most oven doors are very similar in operation. When the door doesn't close well it's generally because the hinges have been stretched/bent when the oven door has been open. To see if this is the case, open the door fully. If it's stretched the door will open past 90 degrees (slope down instead of being horizontal). The easiest way to fix this is to bend it back. Place something as a spacer between the door and the oven on both sides (like a spanner handle or anything strong and about 8mm thick) as close to the hinge as possible. Close the door against it carefully and push the door closed. Do it a little at a time and remove the spacers and try the door each time until you are happy that it closes nicely again. It should be spring loaded closed slightly.
Aug 14, 2013 | De Dietrich DOC310 Electric Single Oven
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 01, 2011 | Neff B1421 Electric Single Oven
OVEN DOOR IS NOT CLOSE PROPERLY.
which subway are you , if the door doesnt close properly you may need new hinges
Jul 14, 2010 | TurboChef C3 Single Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Oven door does not fully close
The usual reason for oven doors not closing properly, is weak door hinges,if it does not close all the way, and the door seal is o/k, then I suggest you replace both door hinges. Please rate my solution. Thamks.
Jun 06, 2009 | Amana AOCS3040 Electric Single Oven
Kitchenaid Superba microwave oven combo close door error
turn off the main power outlet it will work.
Feb 09, 2009 | Ovens
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Oven doors will not close properly
Most of these I have seen have to have the hinges and recievers replaced to get the doors to close properly and keep the light off.
Apr 17, 2008 | Ovens
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
