Question about General Electric Refrigerators
WATER IN THE BOTTOM OF REFRIGERATOR
CONSTANT WATER IN THE BOTTOM OF THE REFRIGERATOR
    Problem Solver:
  • 15 Answers
Get model # to be accurate. but if freezer on top and u get water in fresh food compartment under crisper bins u got blocked defrost drain. as much as i can help with such little info.
Posted on May 13, 2014
3 Suggested Answers
SOURCE: Water in bottom of Roper Refrigerator/Freezer Unit
I have the same problem. I suspect the drain line for the auto defrost is clogged and so the water is dripping down into the fridge. (The water from the auto defrost cycle is supposed to drain into a pan under the fridge where it evaporates over a period of a few days). I have yet to locate the drain line though.
Posted on Mar 31, 2008
SOURCE: I have a water leakage coming out the bottom of my kenmore refrigerator model 52559100
check your defrost drain line. can be located in freezer section. also if you have a filter at the bottom make sure the housing is not cracked. If your frig is cooling then the coil is going to be doings its job
Posted on Jun 08, 2012
Jun 08, 2012 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The freezer leaks water constantly and runs out the front.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 21, 2011 | Amana ARB220RCW Bottom Freezer...
Water constantly drips from the dispenser and also water leaks at the left side bottom of the refrigerator
replace the filter and inlet valve of water.because of that only water is coming continously
Jun 11, 2010 | Jenn-Air JFC2087HRS Side by Side...
Water dispenser is leaking
suspect water is more of a constant drip or is it a flow but part that is probably the culprit is the water inlet valve leaking past it is probably a duel valve one side for ice-maker other water in door good luck ron
Dec 12, 2009 | Maytag MFD2561HE Bottom Freezer French...
Bottom freezer constantly runs till it ices up.
check coils on bottom of box and clean out with air or coil brush
Aug 09, 2009 | Kenmore 72212 / 72214 / 72219 Bottom...
Maytag fridge has constant running water sound
you hear a constant running water sound? look in your manual under "normal operating sounds". it explains all of the sounds. it sounds like you're hearing the refrigerant going thru your evap. coil located behind the rear frzr panel. you unit goes into the defrost cycle roughly every 8hrs and water drip down into the condensate pan un the refrig.
Jul 16, 2009 | Maytag MSD2756GES Side by Side...
Compartments are not real cold/ ice maker stopped working too
It sounds like your refrigerant was leaking out. There may be some settled at the bottom that would explain the frozen water on the bottom. a good appliance store should be able to find the leak fix it and add more refrigerant.
May 14, 2009 | Maytag MSD2454G Side by Side Refrigerator
The water and icecube dispenser constantly leaks water on floor
Needs new solinoid valve. Usually located on the back bottom of refrigerator
Jan 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Dec 27, 2007 | Refrigerators
Refrigerators Logo
80 people viewed this question
Top General Electric Refrigerators Experts
Dan Webster
Dan Webster
Darrell
oldsquare1
Level 1 Expert
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
