Question about Kenmore 67032 Dryer
Clothes won't dry
I had the vent system cleaned out thinking this was the problem but the person who cleaned it out told me that it was actually the blower that was not working. I have had several problems with the dryer since purchased. Can the blower be replaced without having a service tech doing it
    Problem Solver:
  • 11 Answers
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
Posted on May 21, 2014
  • 1028 Answers
SOURCE: Kenmore Gas Dryer-70 Series is condensating and doesn't heat up
reck vent starting behind dryer then to outside try drying a load with vent disconnected may get warm but will prove or disprove vent problem..water is from clothes and is recondenseing because there is no escape to outside
Posted on Jul 02, 2008
  • 1028 Answers
SOURCE: clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Posted on Nov 25, 2008
  • 91 Answers
SOURCE: new dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Posted on Jan 04, 2009
  • 1122 Answers
SOURCE: Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Posted on Jan 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: Wont dry very fast
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
Posted on Jan 30, 2009
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Hi, I actually have a TGDS840PQ1. Anyway, my
Hi
I think you need to check this tip out...
Dryer Maintenance
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Aug 07, 2010 | Whirlpool Dryers
Estate dryer do's not dry fast anymoe
Couple of things to check, the blower fan assembly that is close to the lint filter, might be clogged or the exhaust duct hose might be too long and has too many bents, that restricts the air flow. check also outside for restrictions
Jan 06, 2010 | Estate Dryers
Relatively new dryer takes several cycles to dry normal loads
Check the lint trap all the way down to vent, then make sure that the vent is not crushed in anyway. Depending on the way the person cleaned it they could have actually caused more of a clog
Feb 11, 2009 | Whirlpool LER4634J Electric Dryer
New dryer does not dry clothes, cleaned vent to no avail.
make sure the vent is cleared ,sometimes all of cust / think they clean out but instead make clogg even worse,,, repl/coils remove 2 screews 1/4 in from botom panel heating coils are black in color simple fix,,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
My clothes are not drying fast enough
Hello. I was the last person to post with problems with the Miele T1403 Electric dryer. Just wanted everyone to know I solved my problem and this could solve yours as well. To reiterate I too was frustrated with clothes that would not dry. I could feel heat but the vent/filter light would keep beeping and evetually turn off my dryer. The result would be damp clothes especially towels!! I had a certified Miele dealer come in and check out the machine. This was after I completely cleaned out the lint trap the inside of the machine, and the duct connecting it to the wall. Well they looked at everything and determined nothing was wrong with dryer and I had done a great job cleaning it. Armed with this info I was referred to a company that specializes in cleaning the entire interior duct system of the dryer(Not just the lint trap, inside of machine, and connector tubing). They came today and disconnected the machine again went into the attic and used a shopvac type of machine to really clean the entire duct system. Not rocket science but viola problem solved!! You could probably do this yourself if you have a shopvac with a long attachment (depending on how many bends your system has). The machine is working great and now I know to clean the system at least once or twice a year. I was told that slow drying clothes, extra moisture, machines that are very hot to the touch,etc. can all be symptoms of a blocked vent. By the way a blockage can be a fire hazard. This solution is a lot cheaper than a service call or worse getting a new dryer. I wouldn't listen to the hype about European dryers like Miele or Bosch not drying clothes all the way-could just be a blockage. These brands are very good at shutting themselves off when they get hot (which is a good thing).
Aug 24, 2008 | Dryers
Kenmore 67032 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
