Question about Acer Aspire L100 PC Desktop
AL100 wont turn on
Aspire L100 is plugged in but wont turn on...is there a power on/off button
  • Syed Sobhan
    Syed Sobhan Mar 27, 2014
    Issue is resolved...thanks for your help !
  • Big Steve
    Big Steve Mar 28, 2014
    Cool. YW
  • Acer Master
  • 1,087 Answers
You are plugged into the DC adaptor. Have you checked the mains wall power is working and if your DC adaptor is working? May need a tech with a multi meter. Also there is a fuse on the motherboard, but thats getting tricky
Posted on Mar 27, 2014
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
    You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
    Aug 05, 2010 | Acer Aspire L100 PC Desktop
    Computer wont start acer aspire L-100
    CPU overheated? When you cool it down it will start. You can check whether there are lots of dust on the CPU fan and the chase of the machine, they might block the air flow and overheat the CPU.
    Jul 08, 2010 | Acer Aspire L100 PC Desktop
    My l100 wont turn on the power lead is connected but it just wont come on
    Sounds like a power supply issue. Replace it and it should work. If not then the motherboard is the problem.
    Nov 10, 2009 | Acer Aspire L100 PC Desktop
    Acer l100 wont switch on
    check the power cable to msee if its connected to the walls power soket
    Oct 06, 2009 | Acer Aspire L100 PC Desktop
    Where is the power on button on the acer l100
    moz-screenshot.jpgdear,
    if you have manual see in it on page 27/51 and if you dont have then here is the manual for you, see this page and u will see that the power button is on the front side at a corner...
    http://safemanuals.com/user-guide-instructions-owner-manual/ACER/ASPIRE-L100-_E
    click on pdf file named "Download the complet user guide" and after click that there a new small window will open and ask you to type code that is being displayed on the left side one by one...
    goodluck...
    surely, it will fix your issue so dont forget to rate it...
    Aug 31, 2009 | Acer Aspire L100 PC Desktop
    Hello I have problem my pc acer aspire l100 i have problem power yes light yes job dvd-rw and fan cooler so no screen display monitor only black please can you help me
    Does your laptop beep at all when you turn it on?
    Try unplugging the laptop and removing the battery for 5 mins, then try again.
    If you have another monitor you can use, plug it in to your laptop and see if you can get a display on it.
    Mar 15, 2009 | Acer Aspire L100 PC Desktop
    How do you turn it on?
    On page 14 of the user's manual, they show a close-up of the location of the power button on your Acer L100 Desktop PC.
    If you're missing your user's manual, Here's a link to the PDF version from their website (for the PDF, check page 24): http://www.acerpanam.com/synapse/data/7117/documents/AcerSFF.pdf
    I've also uploaded it to the Manuals section of the Aspire L100 series section of this website.
    Hope this helps,
    -Nick F.
    Mar 09, 2009 | Acer Aspire L100 PC Desktop
    Computer wont start.
    Maybe you have a faulty Power Cord try replacing that first. Secondly check your powersupply's Fan if its turning. Lastly check your power button maybe its defective.
    Sep 18, 2007 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    61 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
