Question about XTM Gear Box/Reverse System - Mammoths/MMT
TOYOTA MMT GEARBOX GOES TO NUETRAL
GEARBOX GETS HOT THEN CAR GOES INTO NUETRAL AND STALLS
My1994 toyota tercel stalls when warm
Could be bad electrical part failing as it gets hot. Coils, ignition modules, crank/cam sensors all can do this. Quite common. Check if you have spark to plugs when it fails. If not, start testing parts. Problem is, they will cool and then test ok so this can be hard to find. Start with ignition module which parts stores often test for free. Run test several times to heat the unit up.
Jul 07, 2015 | 1994 Toyota Tercel
I have Toyota Yaris 2006 1.3 T3 Auto MMT, the car goes to N neutral itself while driving in E easy mode and stops. have to wait fro few minutes and switch the engine again, any idea what could be the...
Without a full scan test of all modules it would simply be guessing at it and that's no help!.. That usually leads to unnecessary parts replacement and that's wasting money... Too many possibilities! Your local independent auto repair shop should be able to do a full scan, parts stores can't!!
Mar 26, 2015 | 2006 Toyota Yaris 1.3
Reset computer
then what goes off.
add 1 noun here.
cars going off cliff? , off pavent to ice, or reverse?
engine stalls? yes, hot or cold engine
transmission goes off, called slip.?
car is too general a term, fine tune that.
Dec 30, 2013 | 2003 Toyota Camry
97 eldorado idles and does not run hot, only when driving car runs hot.
May be its low on coolant or radiator hoses clogged or its thermostat issue,its remaining closed or it can be issue with coolant leaking from somewhere.Or cooling fan not running when when engine gets warm.
There are many other possibilities causing these issues.:----
To troubleshoot the issue yourself,i provide you few very helpful links with solutions:-----
Click the link below:----
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
There are many possibilities for car overheating.
Faulty thermostat clogged radiator/plugged radiator, radiator hose worn out. Coolant running low. Low coolant pressure. Faulty temperate sensor.
I suggest you to go through the troubleshooting details mentioned in the link below:-----
All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
These will help.
Thanks.
Dec 06, 2012 | Cars & Trucks
Once vehicle is warm stalls and loose power
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
These details will help.
Thanks.
Dec 04, 2012 | Cars & Trucks
Vw polo, 1.4 petrol, 1996. when slowing down revs drop and car stalls and can be difficult to start again. when driving it can suddenly get abit jerky, no power from accelerator then loses the revs and...
HOT/WARM START ISSUE
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
Thanks.
Nov 28, 2012 | Cars & Trucks
1991 toyota corolla stalls when driving engine is rebuit and new fuel filter wires cap and coplete distributer, also new throttle pos sensor
Have you checked whether you do have a map sensor and any wires are broken or a vacuum hose leaks?
Sep 09, 2012 | 1995 Toyota Corolla
Toyota 1994 corolla automatic trans. when i put shift in reverse the car sounds as if in nuetral an when i push gas pedal to move the car does not respond. however when i put it in drive it seems to be...
not really it could be a brake band or a solonoid thats inside the box ,could even be the operating solonoid thats under the selector rod inside the gearbox
Jul 13, 2011 | 1994 Toyota Corolla
I purchased a toyota corolla 1.6 advanced mmt 2008 model. I am extremely worried about the gearbox of this vehicle. I have had 2 toyota's before this one, my family members have had at least twelve...
a toyota transmission is much like a honda trans,there are gear to gear trans,like a motorcycle,they don't use bands,clutches,etc.so there shifts are different but don't be fooled by the shift a toyota and honda have the 2 best transmissions in the business,I would suggest getting a bigger model of toyota if you still have issues with the shift,the corrolla is the lower end try a camry,but to answer your question that shift is normal.
TIM............
Nov 04, 2010 | 2008 Toyota Corolla
XTM Gear Box/Reverse System - Mammoths/MMT Logo
15 people viewed this question
Top XTM Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a XTM Toy Expert? Answer questions, earn points and help others
