Question about Logitech Z-3e Computer Speakers
Humming noise hi! I have a problem with my logitech z3e. When I switch it on I can hear a loud humming noise and nothing else. I used to move the cable at the back of the unit and it helped for a while but now it makes no difference. Even my computer is switched off I does the same thing. Since I had bought it I moved house and it made no difference so it cannot be because of the mains. One of my friend has a logitech unit, too and he tried it in my house and it was working fine. I think it can be the problem with the wires but I am not sure so at the moment I cannot use my speakers but looking for a solution somewhere. I am waiting for your reply, Regards, Charlie
    Top Expert:
  • Logitech Master
  • 80,339 Answers
You have a failed capacitor on the power board
Posted on Mar 28, 2017
SOURCE: Logitech Z-5450 5.1 surround sound speakers - no sound from rear right only
Check out the troubleshooting tips on the PDF file at  http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=t2HdY9Si&p_li=&p_accessibility=0&p_redirect=&p_file_id=44208&p_tbl=9&p_id=5190&p_created=1155250699&p_olh=0
(sorry for the long link). Flashing red indicates data loss.
Posted on Aug 07, 2008
SOURCE: speakers won't turn on
Have you checked the fuse in your plug. If the fuse has blown it won't work in any wall socket. Change the fuse for a new one anyway, then try again.
Posted on Sep 30, 2008
SOURCE: Logitech x-230 - left speaker not working when used with 360
Get your system to a repair shop! Note that the problem is in the PB9 jack at the back of the subwoofer and don't try to wiggle anything yourself - they're great speakers, don't do anything you'll regret.
Posted on Oct 27, 2008
Unfortunately I have the same problem. As an electronic engineer I suspect that the power supply part of the unit is damaged. I opened up the module (don' t try it, its a little bit tricky since there is a type of glue around the silver bezel, after you remove the 4 screws from the front holes) and did some quick static measurements with a multimeter, so far no luck. Since I am still in warranty I will try to replace the item. Hint: protect your electronic equipment with ups or surge protection devices.
Posted on Jun 28, 2009
  • 10 Answers
SOURCE: I have Logitech X-230 speakers. The left speaker
CHECK THE POWER SUPPLY TO THE SPEAKERS
REPLACE ITEM IF POWER TRANSMISSION IN NIL
Posted on Jul 18, 2009
Why do my desktop computer speakers have a humming noise all of a sudden? They were turned off for a couple of days .
Check the speaker cables for connectivity. Be sure to securely plug in the stereo jack/s at the back of your pc
Jul 21, 2014 | Logitech Audio Players & Recorders
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
Drivers seat won't move forward or reverse
the main gear drive on the system is most likely broken and that why the cables are disconnected could be a costly repair,or you could look for a local car breaker,adrian,.....
Mar 27, 2014 | 2003 Ford Escape
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
I own a Bose Acoustimass 7. I noticed humming coming from bass more noticeable than before (although I recently moved it to another smaller room) I also noticed when I hear this humming- the higher I turn...
I was having this very same problem. I finally figured out that I was getting feedback to the system because my TV cable coming into the house wasn't grounded right.
Oct 04, 2011 | Bose Acoustimass 15 System
About a week ago I replaced the lamp in my samsung hls24266 with no incident. Now when I turn the tv on, I hear a very loud humming noise. I tried disconnecting the coaxial cable but it does not go away....
I can't explain the timing of your problem and why it showed up after lamp replacement, but Samsung color wheel failures are usually associated with a rather loud hum. I would removed the back, jumper the lamp door switch and try to determine exactly where the hum is originating from. I think you'll find the color wheel is the culprit.
Bill W
integrityhomeworx.com
Mar 08, 2011 | Samsung HLS4266 TV
One of the speakers when turned on loud, there is humming sound. sound hear like a helicopter engine
we need to do a little bit of fault finding here to narrow down where it's coming from or what is at fault.
First try physically swopping the speakers over and reconnecting (do not just switch the cables at the back of the amp). Is the sound still coming from the same side or has it swopped over? If it's swopped over, it's a speaker issue and needs replacing.
Ok, if the strange sound is still happening from the same side, have a look along the speakers cable path. Is the cable running along side any power cables or extension leads or is it near any wall warts or mains transformers (the type you get with mobile phones, keyboards, answer machines,etc). If so, move the speaker cable a considerable distance away from these. Now, has it stopped or the noise reduced?
If we are still not getting anywhere, see if you can try your speakers on a friend's system and/or try someone else's speakers you know to work on yours.
If his/her speakers are noisy on yours, firstly you have to consider that most sytems at very high volume will produce some noise, but if it's actually quite a loud audible noise that's relatively new to the system, you need to get the amplifer serviced.
Hope this helps
Good luck
Jan 07, 2011 | Audio Players & Recorders
The tweeter of my mackie srm 450 V2 makes a quite loud noise (humm). this nois was there right from the beginning, and mackie told me, that this was usual....the older 450´s did not make this kind of...
The latest 450v2 include this metal portion 1 to isolate AC lines over IC's, metal part 2 is include in all versions, some technician remove them and that creates more hum at idle levels, by having both the latest 450v2's are the quietest of the v2's.
V1 did not use switching power supply, they use discrete circuit and that is why they are a bit quieter
Aug 04, 2010 | Mackie SRM-450 System
Drying operation not working.
Kindly notice that are you able to hear any humming noise from the machine if you hear the humming noise means check whether the drum of the machine is moving freely with hands rotation do this after switching off the unit
After doing this if you find that the drum is moving hardly means kindly replace the mechanism
else change the motor of the unit
Jan 20, 2010 | Zanussi WJD1257W Front Load Washer
Loud humming after turning on.
I have sort of the same problem...there was a loud snap(kind of electical spark like) then the unit started humming loudly which changes sound as you move the unit around. The picture remains clear and the fan is quiet in shut down mode...still the wheel you think?
Sep 07, 2009 | Optoma MovieTime DV10 Multimedia Projector
Logitech Z-3e Computer Speakers Logo
61 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
