Question about Franklin FWC100 Wine Cooler
How do I replace the interior light bulb
Cant seem to get the cover off
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Change interior light bulb
If this is the light that is controlled with the center switch, it can easily be changed by carefully prying the plastic cover off and replacing the bulb, found at any local auto parts store.
Nov 20, 2011 | 2005 Lexus Ls 430
I need to replace plastic on the tail light of a 1990 pulsar hatch and cant see how to get the old one out, there seems to only be one screw holding it?
The fasteners may be behind the interior panel of the hatch. Take the one screw out, and if that doesn't release the light, then look for the interior fasteners.
Jan 03, 2011 | 1990 Nissan Pulsar
How to replace interior dome light?
pop the cover off with a flat head screwdriver, remove bulb and install new one . carefull not to touch the new bulb.
Apr 23, 2010 | 2007 Acura TSX
I just bought a 1997 Pathfinder and the interior light doesn't come on when the door is open. All other interior lights seem to work. Would it just be a bulb that needs replacing. I'm assuming the switch...
yes it could be the bulb is just blown remove it and check that the filaments are still 2gether if they are fine it will be the fuse its usually in the group of fuses under your hood the fuse will be labeled dome or dome light this is the interior light it has its own separate fuse replace the fuse there are usually spares on the inside of the fuse box cover but make sure it is the same as the one that is blown
Oct 16, 2009 | 1997 Nissan Pathfinder
Can't get the glas cover off the interior bulb
If you cannot remove cover with normal finger force, then spray with WD40, and grip cover with a pair of vice grips with a cloth wrapped around the jaws, and try turning it that way.
If it will still not come off, then your only option is to break it, and replace bulb, but make sure you can get a replacement cover first.
Please rate my solution.
Thanks.
Aug 20, 2009 | Neff U1661 Double circotherm super...
How do i replace interior light bulbs, and third brake light bulbs..etc....etc?
most of the interior lights can be replaced by popping off the cover and pulling the bulb. usually there are just a few plastic clips that hold it on. as for the third brake light, there are 2 i believe t16 or t17 star screws that hold the lens on. once you have that off, the rest is obvious.
Jun 20, 2009 | 2008 Chevrolet Silverado 1500 2WD
Elddis caravan porch light bulb blown cant remove cover
Take a pair of safety glasses, work-gloves, and a hammer, and swing the hammer to break the cover. Remove the whole unit, and replace it with an energy-efficient LED light & socket.
Apr 23, 2009 | Computers & Internet
Interior light is out.
there are two tabs on light shield grasp both and turn to the left it should come off. if not a little friendly persuassion with a screwdriver should do it. replace with the correct wattage bulb. get an appliance bulb they hold up better than regular ones. should be 25 or 40 watt bulb
Jan 24, 2009 | Whirlpool Dryers
Interior light
No. If you see that the bulb was burned, you can replace it yourself, you dont need to take off the battery terminal since taking it off might cause more trouble to your car. dont worry you cant be electrocuted by a 12V dc by just replacing the bulb
Oct 20, 2008 | 2004 Toyota Corolla
Franklin FWC100 Wine Cooler Logo
44 people viewed this question
Top Franklin Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Franklin Furniture Expert? Answer questions, earn points and help others
