Question about Refrigerators
D965e-rbg amana can it be programd to come on every two or 4 or6 hours
I need a plug for the drain hose hole on an Amana dehumidifier D965E
Are you referring to the drain cap and rubber drain plug in the back of the unit? If so, you can order factory replacement parts by calling 1-888-842-2440. Hope this helps.
Jan 18, 2017 | Cars & Trucks
Amana D965e-e dehumidifier leaking
I encountered a similar problem (using the bucket, but still getting water leaking onto the floor) with my 970E-E. The problem is a design flaw. If the bucket is not firmly pressed into the dehumidifier, there is a slight air gap between the bucket and the dehumidifier on the left side. Within the gap, warm moist environmental air cools. Water condenses in the gap and pools up at the bottom of the bucket shelf, eventually spilling over onto the floor. You can check and see if this is your problem by pulling out the bucket and inspecting for droplets along the left side of the bucket shelf. My solution was the bungie the bucket into the shelf firmly so that there is no air gap.
May 29, 2012 | Amana Dehumidifiers
Can I change the ring count for voice mail to three instead of 2 or 4 OR6
Sorry you cannot set ring count for voice mail to 3.
It has settings to set for 2,4 and 6.
Thanx
Jul 04, 2010 | Uniden TRU8885 Digital Answering Machine
The unit has been on for 4 hours and is still not cold, would also like to replace seal
First off it takes 24 hours for a freezer to bring the inside temperature down to a suitable temperature, but to replace the seal raise the edge of the seal and you will see the track that hold it on, please allow 24 hours to see if temperature drops and repost details
May 12, 2009 | Amana 7 cu. ft. Chest Freezer Deepfreeze ...
When I plug in RBG cable to laptop, it crashes
i need for a msr206 24VDC /-10%, 2.0A Max., external power adapter attached
Dec 17, 2007 | Focus Enhancement i-Tview Gold (444-6201)
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
