Question about Zonet ZFS3116P 16-Port 10/100 Network Switch
How to connect also sonet zfs3116 to my home system
Trying to connect the 3116 to my home network
  • 76 Answers
Can't find manual for it but it says it's a 16 port. If all 16 ports are labeled identically, just use a standard ethernet cable (i.e. patch cable) from the switch to your router. If there's one port that is a different color or labeled uplink or labeled 'wan' plug that into your router. Then plug all your other devices into the other ports.
I'm assuming you have a router. If not get one. You should not be connected to the internet without a router.
Posted on Mar 27, 2014
I can't connect to the network/ wifi for my RCA home theater system, I tried putting in manually but still nothing. Please Help.
Does your RCA see the network? IF so, go to it's settings and assign a static IP to it in a proper range (check router settings first). Then connect manually to this IP (point out connection to that IP in settings).
Feb 26, 2015 | RCA Audio Players & Recorders
Tip
Network Troubleshooting in windows
<p>Some Time Network trouble shooter faced some problem in but they can't solve out where is the exact problem. Yes it create critical situation some time to find out where the problem is. In windows based OS have a feature to take out problem. Network trouble shooter is the feature where we can recognise the trouble of hardware, software or network. Here I will describe about <span>how to troubleshoot a Windows XP-based home network. Usually it will describe also about a network structure, how to use the Home and Small Office Networking Troubleshooter, and how to troubleshoot basic connectivity, and how to resolve file and printer sharing issues. If you have problems with your home network, follow the steps in this article to help isolate and troubleshoot the configuration of your home network's basic connectivity, and file and printer sharing. First, try to identify and resolve the issue by using the following steps. </SPAN><br> <p><span><span> </SPAN></SPAN>At <span>first you have to know the kind of network structure that using there. If you are not sure, go to the "Home-network structures and their configurations" section. To identify the problem first </SPAN><span>Click starts and then click </SPAN>Help and Support<span>. </SPAN><span><span> </SPAN>After that </SPAN><span>Pick a Help Topic, click Networking and the Web. </SPAN><span><span> </SPAN></SPAN><span>Under Networking and the Web, click Fixing networking or Web problems, and then click Home and Small Office Networking Troubleshooter. </SPAN><span>Answer the questions in the troubleshooter to try to find a solution. </SPAN><span>Before you troubleshoot home networking issues, first determine the network structure you are using. The network structure is the arrangement or mapping of network elements such as links and nodes, and the physical connections between them. There are several common home-network structures.</SPAN><br> <p>If in that Lab the computers are connected to a hub, where only one computer has Internet connection shared by using Internet Connection Sharing<b><span>.</SPAN></B><span> </SPAN><span>In this configuration, the computer that shares the connection generally assigns IP addresses to other computers on the home network. The computer that is sharing the connection will have IP address 192.168.0.1 configured for the adapter that is connected to the home network. Other computers on the network will have addresses in the range 192.168.0.<span>x</SPAN>, where <span>x</SPAN> is a number between 2 and 254.</SPAN><br> <p><span> </SPAN>If t<span>he computers are connected to the Internet</SPAN> through a broadband connection, then<b><span> </SPAN></B><span>this configuration is also known as an edgeless network. In this configuration, the computers on the home network each have an IP address that is provided by the Internet service provider (ISP). The addresses that are used vary, depending on the ISP. </SPAN><span></SPAN><br> <p><span>So Network trouble shooter is very useful and easiest process to identify or troubleshooting a network problem.</SPAN>
on Mar 24, 2011 | Microsoft Windows XP Professional With...
I need a manual for the model 3116
this question shows that name of the sewing machine is a singer
so there's where to try for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 3116 ) & click search
Mar 27, 2012 | Singer 3116 Simple
Would like to download a manuel for singer 3116 -simple
Go to the home page
Mar 17, 2012 | Singer 3116 Simple
XP Home W/ No Network System Tray Icon
control panel-network connection-right click on "local area connection" at bottom select "properties" click a check in the box that says "show icon in notification are when connected"
Dec 29, 2009 | Sony VAIO VGN-T150L PC Notebook
Go to Control Panel >> Network Connection >> Right Click - Properties >> there's 2 check box, and check for " Show icon in notification area when connected.
Dec 29, 2009 | Sony VAIO Notebook
Didn't recognize uplink
Not really, you just have a minor misconception. The network feed is not suppose to plug into the uplink. The uplink is for connecting 2 switches together so they act as if they were one switch.
Sep 22, 2008 | Linksys EtherFast 3116 Port 10/100...
Toshiba Satellite Vista operating system not running.
if you did installed soneting just uninstall it hardware or programs then restart the computer all these you can do it on save mode
Jan 01, 2008 | Toshiba Satellite A135 Notebook
Wont sign on to internet
Is the computer recognizing the connection to the network?  Does the home network use DHCP?  How do you have the network setup?  Does this connection work with a different computer?  Try pinging any other computer on the network, and try pinging a website.
Oct 16, 2007 | Compaq iPAQ Home Internet Appliance IA-2...
Zonet ZFS3116P 16-Port 10/100 Network Switch Logo
74 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
