Question about Brother MFC-5440CN All-In-One InkJet Printer
Every time I flush the commode water leaks outside and top of the bowl and into the floor.
I do not know what to do. If can not get to the problem of stopping the leak, probably. I should replace the bowl and Tank. Oh, by the way we just return home a week ago for two(2) months absent due to death in the family.
  • 76 Answers
Seal between tank and bowl dry rotted. Should be able to find a replacement at HD or Lowes. Problem is if it's super old the bolts holding the tank to the bowl are probably rusted solid. May have to drill them out. When that happens to me I get a new unit. Wax seals are more fun than rusted bolts any day and a decent commode only cost $140.
Posted on Mar 27, 2014
Why does water overflow out the top of the inlet valve?
Well the float bar is not turning off its set to high or problem with valve seating passing water . you will probably need to change the whole assembly.
Jan 26, 2018 | Home
Tip
Our commode isn't leaking, yet it refills many times a day
If your commode is refilling over and over, you may have a Ghost Flushing problem. Even though there's no water on the bathroom floor, you likely still have a slow leak somewhere in the tank. To locate and identify the source of the leak fill the tank and shut off the water to the commode. Remove the tank lid and draw a pencil line along the top edge of the water line. Leave the water turned off and go back several times and redraw the pencil line at the water line. When the water stops draining see where the water level is. If the water has stopped just below the overflow tube, you likely have a siphoning problem. If the water drains to the bottom of the tank you likely have a flapper problem.<br />To correct the siphoning problem reset the the depth of the fill tube in the overflow tube. Fill the tank up, shut the water off, and recheck after some time. Repeat these steps until the water stops draining.<br />To correct the flapper problem gently lift the flapper and clean the bottom of the flapper and the flapper seat. Refill the tank, shut the water off, and recheck later. If water still leaks replace the flapper.
on Dec 28, 2010 | Plumbing
Need to increase bowl water level. how do I do that
Step 1:
Remove the top lid of the tank, ...carefully, so as not to break the ceramic by dropping it on the floor accidentally. Inside exists a "lever" attached to a "float" acting as a "fulcrum," with the "float" resting on the level of the water in the tank. The more water in the tank, the more water will enter the bowl, at flushing time.
Step 2:
The level of water in the tank corresponds to the level of water entering the system upon flushing the commode (bathroom fixture). At the bottom of the tank exists a "flap" type of device (usually). As the water exits the tank into the bowl the flap seals off again, discontinuing the water's entry into the bowl. This should always seal off at the end of a "fllushing cycle." The more water in the tank at the beginning of the flush, the more will enter the bowl.
Step 3:
Therefore, raise the arm of the "lever" (sometimes it's a "vertical" post with an "adjustable float" on it; in what case one raises the float on the post, by depressing a "clip" like device on the float itself, sliding it up versus down) by bending the arm upward, ...carefully. The increased water in the "tank" by the above process should solve your problem. Be certain to note whether the "flap" closes prematurely (It shouldn't), adjusting the flap's "chain" (held up by the "handle" itself) should it close prematurely.
Step 4:
You may need to tighten the "nut" (fastener) on the "handle" inside the tank as the "chain/flap" may simply be closing prematurely, because it's "loose" (easily tightened by hand at times, versus with a small, adjustable wrench bought at a "hardware store" like "Ace Hardware").
Step 5:
The above items (one, versus several of them), should solve your problem.
Jan 19, 2013 | Jacuzzi Bath Maxima EL61 959 White...
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Waste not always leaving the commode bowl.
I'm guessing here.
It sounds to me like you may have a vent proglem. I presume a professional plumber did your conversion? You may want to call him or her back to adjust the tank water level. This will assure you have at least the minimum amount of water required to create the suction necessary to draw the waste down the drain. A partially obstructed vent and/or low water level would contribute to the trouble you describe, though it could be something else.
Let me know if this works for you.
a
Sep 21, 2009 | Health & Beauty
Leaking commodes what i need to know is how much should the drain pipe needs to show above the floor before i install the commode
the floor flange..where the toilet bolts go, should be on top of finished floor and screwed down .it should only be apox.3/8"higher then finished floor.you often have to cut a tapered hole so floor flange sits correctly
Aug 15, 2009 | American Standard Home
Water comes from bottom of tank when commode is flushed. I have a two piece toilet, upon flushing it water pours from in between the two joined parts-tank and commode. I have the same problem. Water leaks...
Ok the toilets work is that the tank reservoir is where your fresh water....is stored....and the flush valve...(if you take the tank lid off you will see that the handle is either connected to a chain or uses a lever to lift something called a flapper....it is usually black but it can be gray..or blue...also there is a flash valve that is a long tube and a round bottom with a rubber gasket...that seals the flush water into the tank...reventing it from entering the bowl.......when you lift the handle water dumps from the tank...into a s-shape tunnel called a trap...(this is in place to prevent sewer gases from entering the house the water sits in the bottom of the trap acting as a seal against smells...gas...etc...from the sewer line....Now your tank is mounted to the bowl by (2 or 3) bolts that you can see and access from inside the tank...however the person doing this will have to also reach under the toilet where the tank mounts to the bowl and hold a pair of pliers or a crescent wrench on the nuts which hold the tank in place.....after these are removed...the tank will lift off of the bowl.(now obviously the water has to be shut off and be disconnected from the tank....when the tank is lifted ...a small amount of water may spill out ...but it is clean water...so no worries....since the tank and the bowl are made of porcelain they obviously would not seal just sitting on top of each other so the tank...has the bottom part of the flush assembly which is mounted to the tank by way of a large plastic nut extends out of the bottom opf the tank 2-3 inches......around this is another black or gray about 3-5 inches in diameter...and costs less than $5 at Home Depot.....change this out, reassemble and your back in business. Be advised that the flapper in the bottom of the tank...if you ever have to change it out and the tank gasket you are going to change out (after a long period of use or just time and deterioration)...leave black residue on your hands...if you handle them...but it is safe and easily washed off...it just may freak.. a layperson out....so one may want to use some gloves they can toss afterwards....Any other questions....and I can absolutely answer them in regards to toilets...as i have repaired and or replaced 2500 - 3000 in my 35 years in the apt/home maintenance industry.
I hope this helps.....thank you for rating my effort...and good luck....tha Fang.
Mar 29, 2009 | Home
You need a new tank gasket. It is a rubber piece that seals between the tank and the bowl. They are fairly inexpensive and if you have patience and a little plumbing know-how; they can be changed at home. Here is a good on-line set of instructions:
http://wiki.answers.com/Q/How_do_you_change_the_gasket_between_the_toilet_tank_and_the_toilet_bowl
Mar 27, 2009 | American Standard Colony 2388.012.222...
Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Dec 21, 2008 | Home
Brother MFC-5440CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
