Question about Acer (91.40C28.003) DVD Drive
TOSHIBA MK1237GSX HAVE PROBLEM dise drives - Acer (91.40C28.003) DVD Drive
Mk1237gsx fix clicking
Posted on Dec 20, 2009
I have a toshiba hdd2d62 mk1237gsx. now the usb slots on my pc picks up the hdd but when i click into my computer and the click on the hdd drive it wont open.. have i lost my data cheers.
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 08, 2011 | Toshiba 120GB MK1237GSX 2.5" SATA II 120...
I have the blue screen of death for my Toshiba MK1237GSX - (SI) laptop. I've tried all the advanced system reboot options already and everything gives me the BSOD. (I used F8 and F12) Can I do a full...
HI, MOST LIKELY A FRESH INSTALL WOULD BE IN ORDER. THERE A LOT OF UPDATES TO DO AS WELL.MAKE SURE THAT YOU DO YOUR ANTI-VIRUS BEFORE ALL OF THOSE UPDATES. .....DO THE "OPTIONAL" UPDATES LAST!!....HOPE THIS HELPS.......JEFFXC
Jan 30, 2011 | Toshiba 120GB 2½ inch 5400rpm 8Mb Cache...
Was installed in a Dell Laptop and someone set the Password on it. Now need to move it to another Inspiron 6400 but it is not able to get past the menu at the start asking for the Disk Password to be...
Hard disk passwords protect data on hard drives and moving the hard drive into another computer will not unlock the hard drive unless you have this password.
There are no backdoor password available.
Dec 14, 2010 | Toshiba 120GB MK1237GSX 2.5" SATA II 120...
Mi psp funciona bien;pero cuando conecto la psp con el cable usb a mi portatil, mi portatil no la detecta.¿Qué puedo hacer?
te vas alas opciones i hay un lugar donde dise algo de usb conecion conectas tu psp ala computadora y luego le apachuras donde dise usb coneccion i en la computadora va a salir un folder y aista
Jan 07, 2010 | Sony PlayStation Portable (PSP) Console
Dise unreadable
Most likely you will have to buy a new or used game because the xbox reads everything off the disc and if its scratch you will not be able to play the certain places that doesnt work or not play at all
Aug 19, 2009 | Microsoft Xbox 360 Console
I cant restore my toshiba labtop
If the restore discs don't work, then another alternative is to load it from an O/S installation disc. Look at the bottom of the laptop, it should have a license sticker on the bottom. If you have a friend that has an installation disc that you can borrow, it must be the same O/S version, you can re-install the operating system but use your license. This will allow you install a clean version on your system. It should be enough so you can get online and continue to download any missing drivers from the appropriate vendors. Good luck. -Carlos:
Jun 13, 2009 | Computers & Internet
DVR K17LF Insert a disc
Hi, according to what I understand the unit works for some situations especially but you cannot visualize the content, in this case the problem that you one presents shows off to be Cd-DVD's unit that this trumping, if the equipment this one even in guarantee, you must come to an CAS or Center of Authorized Service, in order that they diagnose and replace the unit
Dec 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Satellite laptop hard drive crashed
you can have Toshiba MK1237GSX - 120 GB - internal - 2.5 inch - SATA-100 - 5400 rpm - buffer: 8 MB
this hard drive will work with your consisting config.
find it here :
http://www.sparepartswarehouse.com/Toshiba,Laptop,Part,MK1237GSX.aspx
Dec 28, 2007 | Toshiba Satellite A75-S211 Notebook
Acer (91.40C28.003) DVD Drive Logo
315 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
