Question about Sony KDL-52W5500 52 inch Multi-System Full HDTV 1080p LCD TV
Sony 52w5500 No image, No backlights, 13 and 14 blinks
Hi, my 4 years old TV just "died" When I'm starting it, I've got sound, but no backlights, and no image (T-Con) What would be the reason for loosing the baclights (balancer/inverter) and the image (T-Con) the same day ??? The only common point would be the Powser Supply board ? or Main board ? Any suggestion ? Thx
    Top Expert:
  • Sony Master
  • 74,459 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 28, 2014
  • 150 Answers
SOURCE: I have a 4 month old sony bravia 1080 120mhz Sony
Not common but electronics are electronics , we can have failures right out of the box. Generally Sony is reliable and I must say that you should not have to worry about cost , Is it not under warranty - its only 4 months old !!
Posted on May 13, 2009
  • 10 Answers
SOURCE: Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
Posted on Sep 01, 2009
budmrtn
  • 11361 Answers
SOURCE: my tv sony bravia 46" are still not workin i still
So before ordering that expensive main board, you may want to read below and check the T-CON board also:
This is from SONY's how to troubleshoot T-CON board/LCD panel problem:
PM me if you wnat me to send you the whole artical, budmrtn@aol.com
Troubleshooting a "DEAD" TCON
Many of the Sony television models over the last few years will detect a TCON that has completely failed. The
communications data between the video process circuits and the TCON will cease to communicate if the TCON
fails completely. This will cause the television to shut down and display a diagnostics code indicating a failure of the TCON. Not all chassis designs have this feature and it is not found on older models.
The typical scenario when this failure arises is for the technician to bring a video process board to the repair
location. It is usually safe to assume that the problem lies on the TCON board if the replacement video board
does not remedy the problem since it is highly unlikely that a replacement board with the same failure was
received.
One trick to check most TCONS for functionality is to loosen the LVDS connector at the TCON (as shown In
Figure 3) while the unit is turned on. Handle the LVDS connector with care and be certain to fully release the lock
tabs. Gently rock the cable in and out of the connector while observing the screen for any response. Depending
on the chassis, the symptoms of the screen may be gentle white flashes, intermittent colored lines, or a screen
full of random patterns. The idea at this point is to provoke some kind of response on the screen. TCON boards that have failed will not usually generate any type of response on the screen.
Another helpful procedure is to rapidly heat and/or cool the TCON with hot air devices or circuit coolant and
watch for patterns to appear on the screen."
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Jul 16, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony Bravia KDL-46NX810 shuts off with 3D input only
Well written question but I would first call Sony Customer service to see if known issue or if the data base shows any reports or recalls for this issue.......
Posted on Oct 30, 2012
  • 84 Answers
SOURCE: Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Posted on Mar 22, 2014
Testimonial: "Thx for the answer would both give a black screen or one could give a black image ? What I mean is that right now, no light is coming from the TV, so would resolving the TCON or the Balancer problem give me some light but with a black image ?"
SONY KDL-52W5500 red light blinking 13 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 02, 2014 | Sony KDL-52W5500 52 inch Multi-System Full...
Hi, I turned on my 4 year old Sony 42" plasma today and the screen was black with speckles of colour flashing for a few seconds before fading out and the whole screen goes black. The sound was fine...
in sony 42 inch what is the exact model number of your TV?
also can you tell be how many times does the stand by light blink. that would help us to decode the problem in your TV
thank you
Aug 16, 2008 | Televison & Video
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
Toshiba 37xv500p backlight fails
I have only ever done one, several years ago, but this you tube video should help
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Mar 13, 2017 | Toshiba Computers & Internet
I have a 42" Sony Plasma Model# PFM-42B1 was watching tv when picture went out. Red standby light keeps flashing. Was told to unplug for 5 hours then plug back in & count how many times it blinks,...
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Oct 01, 2009 | Sony PFM-42B1 42 in. HD-Ready Plasma...
My tv turned off ..red lamp light blinking nonstop..what do i do???
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony tv with no image
When i turn the tv on there's no image and the red light blinks twice each time, but no sound or image or any sign of anything.
Please help me with this problem, my tv is a sony kv-25 with more than 10 years of age.
Mar 16, 2008 | Sony KP-46S25 TV
Sony Trinitron KV-29RS22 Blinks
Sounds like the high voltage is marginal.
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board by sending it to Module Exchange at 972-298-1212,
or PTS Electronics 800-844-7871 ptscorp.com.
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Feb 10, 2008 | Televison & Video
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Sony KDL-52W5500 52 inch Multi-System Full HDTV 1080p LCD TV Logo
95 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
