Question about Sony DVP-NS57P
Low volume output signal.
Have Sony DVP-NS57P DVD player. It's connected to a flat screen TV using the AV cable. In order to hear the sound, we have to put the volume almost to max on the TV. My father, who has hearing issues, cannot get it loud enough, even at full TV volume. When I plug my VCR into the same AV port on the TV, the volume is normal. I have also tried plugging the DVD player into the 2nd AV port on the TV, but I have the same problem.
    Master:
  • 405 Answers
Have you tried a different cable.
Posted on Jul 09, 2017
kevin000
  • 1847 Answers
SOURCE: Buzz in Samsung Digital when DVP-NS57P Sony is played back?
the buzzing sound is coming from one of the bad ic
Posted on Jul 08, 2008
  • 3 Answers
SOURCE: unlock region code on Sony CD/DVD Player DVP-NS57P
I don't have a solution, but I know that the one about "press Display, Top Menu, Clear, Power" doesn't work.
Posted on Oct 12, 2008
mistersony
  • 320 Answers
SOURCE: SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Posted on Nov 02, 2008
welcomejee
  • 10594 Answers
SOURCE: i did some stupid settings with progressive output. now the tv screen is blue and i can hear the DVD running. Menu is also not visible.
Put player in standby mode, Press 369 on DVD player remote, power up. This will turn off progressive mode.
Posted on May 26, 2009
ripleymojica
  • 643 Answers
SOURCE: how to convert my dvd sony DVP-NS57P in multizone.
go into set up menu undet audio. you have to turn on the dolby digital and the dts. use a fiber optic or coaxial cable to enable
Posted on Jul 11, 2009
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
Why original DVDs appear in Black and white only when palyed on the Sony DVP-NS57P player?
Usually, when you get a black and white version of the film, either the cable connection is messed up or the dvd signal and the tuner are mismatched (say NTSC TV getting a PAL signal from the dvd).
The cable mismatch would be connecting composite video output (using the AV cable that came with the unit) to one of the three video jacks of the component video input on the TV. The obvious first thing to check is that the cables are good and in the correct configuration (yellow to yellow for composite or red, green and blue to red, green and blue). Try a new cable in case there is a damaged cable, particularly with a component video cable.
The tuner mismatch is more common with the handheld dvd players.
I hope this helps.
Jan 08, 2011 | Sony DVP-NS57P
Manuals for sony dvp-ns57p
please check the link below:
http://www.generalmanual.com/DVD-VCRs/Sony-DVP-NS57P-B-S-DVD-CD-Single-Disc-Player.htm
on the bottom of the page after the description, you will find the Owner Manual.
please check it, it should give you all the solutions you need.
thank you.
May 18, 2010 | Sony DVP-NS575P DVD Player
Sony Bravia 40'' LCD 240Hz TV can't get video signal from DVD
Are you absolutely sure you have it wired up right? Are the Cable RIGHT wires color to color, is the "Correct Input" selected? Remember you do NOT use "Channels" but an AV, AUX, or External.input. Most DVD etc, use AV, IE: Yellow, (Video), Red, (Audio), White (Audio) for the OUT connections. These go color to color at TV end. And uses 3 Cables. The "Other" type of Output/Input is Component Video. This is ALL Video, Red, Blue, Green, these go color to color as well. BUT you MUST also send the Sound, Via the AV, IE: The Red & White, AV, Audio IN/OUT connections, So you in this case would have 5 cables/connections in all.
Feb 13, 2010 | Televison & Video
I have a Sony dvp ns57 that was given to me brand new but no manual. I cant seem to get it to work. Can you recommend how to set it up with an ilo tv. No cable box involved. I only have regular cable. Any...
For Manual, appending the link of official Sony Website- http://www.sony-asia.com/support/manual/product/dvp-ns57p/modelfirst
Follow instruction & download it.. its very simple.
For Connectivity with any standard CTV, get for AV (Composite) Cable with RED, WHITE & YELLOW ports at both ends. Connect one side ends of cable to DVD Player back side where LINE/ VIDEO OUT is written for video & RED & WHITE to R & L ports respectively. Similarly in TV other ends are required to connect with AV IN.
NOTE- Make sure corresponding ports are required to connect with same colored jacks.
I m sure this will definitely help out.. if no, plz let me know.
Mar 16, 2009 | Sony DVP-NS575P DVD Player
Sound output reduced
There is a volume control on the Remote of your DVD player , increase the volume in that and it should solve. Additionally check the audio output cord of DVD player if it is intact and tightly fitted.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 22, 2009 | Sony DVP-NS57P
Nov 02, 2008 | Sony DVP-NS57P
How to change from tv to dvd mode
the difference between tv and av, is that av has no showers on the screen. if you change to av you will notice a blue screen, connect your yellow on vedio output and white/ red on audio out of tv
note- before connecting to a vedio touch a tip of your vedio cable some lines will show on your screen, if touch your audio tip harming noise will sound on your tv. if this two happens then you know that your cables are okey. hold your channel button on your tv, channel will start runing after all rf channels finish, tv will go to av.
Oct 13, 2008 | Sony DVP-NS50P DVD Player
Greetings,
Check the audio connection, the port on the TV might be grounded.
While playing, try moving the connection in the port.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 08, 2008 | Sony DVP-NS575P DVD Player
Sony DVP-NS57P Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
