Question about Konica Minolta bizhub Office Equipment & Supplies
Konica C550 Misfeed error how to get rid of it?
After every print the misfeed error occurs
  • 76 Answers
I know this sounds silly but some try flipping the paper over, then try turning it 180 degrees. Printer paper has a grain (a direction that allows it to feed through the printer better).
Posted on Mar 27, 2014
  • 163 Answers
SOURCE: Misfeeds
DEAR SIR WHERE YOU REMPVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEAZ CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Posted on Sep 16, 2007
CopierOne
  • 30 Answers
SOURCE: How do I clear misfeed.
In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
Posted on Sep 17, 2007
  • 4 Answers
SOURCE: clear misfeed (A) on display screen
There is a thin black plastic armature with a tiny flag on the end of it. that flag movement trips a switch everytime a copy passes over it. If this arm is not seated right, then the flag is not dropping between the switch and which is why the jam lite is staying on. if you open the right sided acess jam door and look straight in, down in the lower right corner you should see this small black box shaped switch, it has 2 thin white wires connected to it By removing the paper tray, you can reach in and try cleaning it with canned air if its not the arm and flag hung up, dust in it is causing the problem.
Posted on Dec 01, 2007
Kevin Hayes
  • 167 Answers
SOURCE: misfeed and PDF failure
Thewre could be even a small piece of paper stuck. Try looking even closer, and even open a close the access lids to reset the triggered switch. Even a minute pice of paper in the wrong location can cause a sensor to be triggered and until it is reset it will not work.
Posted on Apr 09, 2008
jaylex
  • 417 Answers
SOURCE: Paper Misfeed Problem
When you close the doors does the message disappear? If so then the paper pickup roller is worn. Open the cassette remove all paper apart from one sheet. Spray a alcohol based cleaned on the leading edge of the paper. Try and do a copy this will issue a jam and also clean the pickup roller. repeat a few times then clean out the cassette and dry off place new paper in the cassette and try. Also there maybe a piece of paper behind the cassette. Remove cassette and reach in and remove paper lodged at back.
Thanks Jason
Posted on Aug 17, 2008
My konica minolta has a false misfeed showing at fuser area
Check all the sensors, the sensor in the fuser unit might be broken, common thing
Sep 06, 2014 | Konica Minolta Bizhub C550
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
Misfeed error occured and wont go away
remove the rollers and clean them for the draw with the problem, use a different draw if they need to be replaced
Jun 10, 2014 | Konica Minolta bizhub Office Equipment &...
Oki b6250 misfeed paper
oki B6250 printer,what is the misfeed error and then shows paperjam
Nov 11, 2013 | Konica Minolta Minolta Di351 DiAlta...
Paper misfeed
828120c7-b2c6-4ef1-86da-8d12eb17847a.jpgkonica minolta c451 printing this type
Jun 03, 2013 | Konica Minolta Bizhub C451...
Bizhub C35 misfeed error
This video will show some of the most common causes for Bizhub C35 misfeeds
https://www.youtube.com/watch?v=Sbo0gon8EIY
Feb 26, 2012 | Konica Minolta bizhub C351 All-In-One...
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
Misfeed and PDF failure
Mar 31, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
