Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Had a humming noise from washer it would fill but that was it dryer worked. Replace the capacitor now neither will run. Are the leads the the capacitor reversable both sides were red colored. Could I
Why would nothing start.
    Master:
  • GE Master
  • 676 Answers
Has the breaker tripped? it the doors shut? is there any lights, need to know everything you are seeing and hearing to help.
Posted on Mar 30, 2014
barkencoa
  • 3463 Answers
SOURCE: Fills up ok,but wont wash,,has a humming sound.
Yes, you need to fit new brushes, if motor still does not go, then it is probably faulty.
Please rate my fixya solution.
Thanks.
Posted on Feb 04, 2009
kachbibi1
  • 979 Answers
SOURCE: WHDSR315DDWW, Fills then just sits there and hums.
Push down on the agitator. You may have to hold the activating button in with the lid up so you can do this. Press down firmly on the agitator and it should start rotating. If it does, you need to have it replaced. If it doesn't, then let the store know and they should take care of it. You should not put any money into since it is new. Anything you do from this point will cost you some money to fix.
Posted on Feb 07, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Posted on Feb 13, 2009
canbruce75
  • 1776 Answers
SOURCE: washer won't fill with water
A water level switch regulates the washer's fill volumn. The switch is usually a diaphragm like device with a small clear tube attached between the switch and the bottom of the washer's outer tub. It works on water pressure on the air in the tube. The switch can be tested using an ohm meter or multimeter. The switch should have continuity. If not, it is defective and will need to be replaced. Hope this helps and best wishes.
Posted on Jul 23, 2009
  • 14 Answers
SOURCE: GE Spacemaker Washer/Dryer wont start only washer or only dryer
check power from the out let make sure they got 220 v
Posted on Mar 03, 2010
Will not spin out, just hums
Probably a capacitor problem, see Amazon.
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums
? 6:42
https://www.youtube.com/watch?v=WMvHOtTaTZ4
Feb 26, 2014 - Uploaded by canyonman1963
Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums - Testing ..... It does not do this every time but about every 3 outof 5 times.
Kenmore Washer Diagnostic - Hums, Will Not Run After ...
? 3:34
https://www.youtube.com/watch?v=C5F-_U0_hYw
Jun 29, 2013 - Uploaded by ApplianceVideo.com
Repair your own Kenmore Washer with these following problems:Hums, Will Not Run After Filling Only at ... Find out why. Close ... Whirlpool & Kenmore Washer Won't Spin or Drain, Just Hums- Testing Capacitor, Waterpump ...
Dec 10, 2015 | Kenmore Washing Machines
Hi, my 6 month old Simpson 5kg Eziloader dryer blew a fuse today. Have plugged it into a different power plug and now its not working and making a humming noise. Any suggestions?
have a service technician come and look the start/run capacitor for the motor
blowing a fuse then humming indicates a capacitator problem
Jul 07, 2015 | Dryers
I replaced the motor, but it still will not work, washer will fill, and drain, but tub will not rotate and makes a humming noise
Classic symptom of the starter capacitor- did you replace it before replacing the motor?
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 05, 2011 | Washing Machines
Washer turns on, fills with water, then will not run, only makes a humming sound when cycle should be starting.
The electric motor of the washer has a capacitor which adds a temporary extra phase to start the motor. If this part is in bad condition the motor will not start, tha´s why you should first check visually this capacitor because when it gets burnt it is easy to see as some molten plastic gets out of the aluminum or plastic can in which the capacitor is kept. Then you get it out and buy a new one of the same settings(it is writen on it).Put the new one back in place and start the washer again.
Read more : http://www.ehow.com/about_66783_ac-motor-need-capacitor-start_.html
Feb 14, 2011 | Whirlpool and Maytag Washer Accessory
Makes electrical humming noise but does not pump water
This is could be the capacitor that has failed. The capacitor gives the motor the initial kick in the right direction to get it started. You can confirm it is a failed capacitor and that the motor is still ok by flicking the fan blades with a stick in the direction it should spin just as you switch the pump on. The pump should run normally. You can get them off Amazon or ebay for around 5 Pounds (GBP)
Oct 11, 2010 | Karcher K2.26 Electric Power Washer
Leaks when filling
It could be a swollen impeller inside the pump causing it to wear a hole in the plastic housing and making the humming noise .It,s fairley easy to replace as it clips on to the end of the motor.Hope this helps.
Nov 28, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore dryer stop working after a lightening storm. checked breakers appears ok, but when you push start switch after setting timer i hear humming noise coming from timer but dryer will not come on.
It is very possible the humming is not comming from the timer, but the motor. check the capacitor on the motor. it should be a 5 or 8 microfarad cap .replace it. Dont try and run motor like that anymore untill it is checked.
Sep 24, 2009 | Dryers
Washer Won't Fill, New fill Valve, makes humming noise
Check your water level switch it may be showing full. If it is it won't fill. If you can set it on spin and run for 2 or 3 min. it might clear the hose from the tub to the switch in case there is too much water in it. Or you could pull the hose off the switch and blow in it to be sure it is clear. Sometime if it gets too much in it it builds up too much pressure and shows full.
Jun 09, 2009 | Washing Machines
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
Humming noise
sounds like the motor is froze
Dec 16, 2007 | Kenmore 24032\24036 Top Load Washer
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
