An engineer came over and changed the purge unit but the problem still appears. I displayed E161-4050 after the printhead replacement.
SOURCE: I keep getting a printhead error....
Check the wiring assemble connecting the printhead to the printer and where the wiring connects to the printer. Anything loose here would prevent the unit from correctly reading the sensors on the printhead. Just a thought.
SOURCE: Printhead (R), Check Printhead - Canon IPF5000
first of all print a nozzlle check....then see all the color patterns.
The second you can do is to update the firmware to the latest version.
But i think that you have to replace the print head.
SOURCE: Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
SOURCE: paper alarm; printer keeps printing same job
remove all supply and then plug then attach data cable, uninstall printer driver and install again
SOURCE: Display shows "check printhead"
Hello Neil, If the quality of print is fine then i dont think there is a problem with your printer head. It must be some error with the software or some other part in ur printer. Do check the printer for some other faults.
