Question about Olympus SP-565 UZ Digital Camera
My flash won't work, is there something that needs to be turned on
I called and was told to put the dial on the p and it would flash but it does not. What else can I try.
I can see something called "Exp Sim" in the bottom right corner of my 1100D. It flashes sometimes and is displayed continuously when I click a photo. What is this?
"Expo Sim" (Exposure Simulation) shows what your picture would look like with your chosen settings. For example, put the camera in full manual mode, start Live View, start turning dials and you'll see changes in the look.
Apr 07, 2013 | Canon EOS 1100D / Rebel T3 Digital Camera
The 2003 Concorde my mom has won't start right away sometimes after it's turned off not because of anything mechanical but something with the security i was told. Any thoughts on how to turn t
Typically dealers are the only people who can work with the security systems on cars. If it is a factory security system, calling a dealer would be your best option. If it is aftermarket, call the company that installed it. If you have a mechanic you trust, you are free to ask them for advice, but typically mechanics will refer you to a dealer for security system issues.
Oct 24, 2012 | 2003 Chrysler Concorde
Night service won't ring
Log into the mailbox and check the setting via ADMIN or 8 then press 8 again to set it up.
Make sure your cell # is in there and see that its told to grab the right line, pool or route. If all seems ok but still an issue then you need to call your vendor in to look at system/lines.
Sep 25, 2012 | NorStar T7316E Corded Phone
I changed the battery in my 2001 grand am ....now it won't start
mine does the same thing, but my security light flashes. I was told that it is the security system on the car not recognizing the key. The key I am using is the original key for the car though. I was told that a quick (but not so quick) fix is to open the door, put the key in, turn it on but don't start it.... set for roughly 10 minutes so the car will reset itself. It works everytime but is a pain in the ****. Was told the only way to completely fix the problem would be to put a new motor in it.
Dec 05, 2011 | 2001 Pontiac Grand Am SE
At work we have a panasonic kx-t7668 telephone. I have followed the instructions on (one-touch dialing), but now when we have incoming calls in the office i dont have a red light that flashes at me, so i...
Did you do something stupid like program over the top of the buttons? Press PROGRAM and, starting from the bottom press a button, then dial 0 01 STORE Move up the line and press 0 02 STORE etc. Do that for however many lines you have and it puts the lines back into the Single-CO sequence that you probably started with. (PROGRAM is done from an idle phone and you press PROGRAM to exit).
Carl
Apr 01, 2011 | Panasonic Lands Phones
My KX-T7030 phone will not send a tone during a call, so I cannot "Press 1" or any number to use automated options. It does dial numbers ok??
If it dials O.K., try pressing # and see if it turns on the DTMF pad. You could have pulse dial on outside calls enabled, and that would keep the keypad in pulse mode until it's told to send tones.
This is really only a guess. The type of dialing is programmed in CO trunks and it's possible it's been set to Call Blocking! It is designed to send pulse only and block the audio of DTMF so the CO won't get confused. You might start with changing the Type Dial to DTMF and test. If that doesn't work, try Pulse and test. Last, if that doesn't work, you will need to keep call blocking and try the # after dialing.
Please comment back if it does or doesn't work. We don't see much pulse dial around here.
Carl
Dec 09, 2009 | Panasonic KX-T7730 Corded Phone
Need to have 3 way conversation on Panasonic KX-T7730
Steps
  1. Call your friend.
  2. Tell them that you will connect your other friend.
  3. Press talk to put your first friend on hold.
  4. Dial your second friend's number.
  5. Press talk again.
  6. Wait for them to answer.
  7. When they have answered, press talk again to bring the first friend back on the line.
  8. You made a three way call!
Option 2
  1. You can press the button that says 'flash' on the phone.
  2. Then dial the number.
  3. Press flash again.
Option 3
  1. While on the phone dial a number and press call/talk.
  2. When the dialed number answers press the options button.
  3. Select merge/join/combine calls or press call/talk again
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Panasonic KX-T7730 Corded Phone
I can't hear anyone, nor can i be heard, when making or receiving calls
Sometimes there might just be lint or something in the headset port. Try taking some canned air and blow it out or take a headset and plug it in and out a few times.
Sep 14, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Olympus SP-565 UZ Digital Camera Logo
21 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
