Question about Sony Car Audio & Video
Audio jack doesn't work
Seems to lose power at random times. Best Buy installed the stereo. It is a Sony CDXGT57UP
2 Suggested Answers
pctech1
  • 1940 Answers
SOURCE: I have a sony explod car stereo without rca jacks
INPUT:
SCOSCHE FAI-3A - SONY XPLOD HEADUNIT
A1 - Grey (Right Front +)
A2 - Grey/Black (Right Front -)
A3 - White (Left Front +)
A4 - White/Black (Left Front -)
A5 - Green (Left Rear +)
A6 - Green/Black (Left Rear -)
A7 - Violet (Right Rear +)
A8 - Violet/Black (Right Rear -)
OUTPUT:
SCOSCHE FAI-3A - AMPLIFIER
B1 - Right Front + (Not Used if using RCA)
B2 - Right Front - (Not Used if using RCA)
B3 - Left Front + (Not Used if using RCA)
B4 - Left Front - (Not Used if using RCA)
B5 - Left Rear + (Not Used if using RCA)
B6 - Left Rear - (Not Used if using RCA)
B7 - Right Rear + (Not Used if using RCA)
B8 - Right Rear - (Not Used if using RCA)
Right Rear Output - REAR RCA IN (White)
Left Rear Output - REAR RCA IN (Red)
Right Front Output - FRONT RCA IN (Red)
Left Front Output - FRONT RCA IN (White)
Note: Be sure to connect the Remote Turn-On from the Sony Xplod (Blue/White) to the Amplifier's Remote Terminal. All that's left is to connect the 12-volt power wire to the Amplifier's Power Terminal and a Ground wire to the Amplifier's Ground Terminal. Also, switch the FAI-3A to Line Out using the switch on the left side of the device, and ground the FAI-3A using the device's ground wire.
If you need any more help, let me know.
Posted on Jun 08, 2011
I want to connect my stereo to the tv to work like a sound system. What plug on the to do I have to use
You will need a cable with red and white RCA plugs at both ends. Audio out from the TV Red And White jacks on the rear or side of TV to red and white AUX jacks on your stereo Most older flat panel TV's have the red and white audio out RCA jacks **NOTE Newer flat screens like Samsung Smart TV only have digital sound output, or HDMI and if your stereo doesn't have an optical sound input. You can buy a digital to analog adapter at Best Buy or Wallmart. Hope this helps!
Feb 14, 2016 | Televison & Video
I have recently purchased SONY MDR-DS6500 wireless headphones. Wireless transmitter have two inputs (1) Audio In : Optical Digital Input (2) Analog Stereo Input mini jack. I would like to hook it up to my...
Its all about the quality of the converter in the Headphone unit.
If the quality is lower than the quality of the converter in the receiver, then using the head jack is a better idea. Since there is more room, power, and money going into the receiver, it may be better
I do not believe that there is a cheap way to connect to the headphone with optical audio
The only way to be sure though, is to test it and see. Connect your computer to the receiver with HDMI, play audio through, and compare it to when you just connect your computer to the headphones, via optical audio
Oct 21, 2013 | Sony Audio Players & Recorders
Sony stereo mhc-gx9900 audio doesnt come out of speaker thou all lights show its playing
There is a intermittent problem on the main board, or the headphone jack is dirty or worn contacts, buy electronic cleaner, spray into headphone jack or earphone jack, slide headphone jack in and out as you spray the contact cleaner, do this several times in a attempt to restore audio.
Apr 06, 2012 | Sony MHC-GX9900 Shelf System
Trying to connect laptop and getting a hissing noise.
You have not told us how you are attempting to connect the laptop. You would likely use a 1/8 stereo to RCA Wye cable to plug into the CD input jacks. You could also have a 1/8 Wye stereo to 1/4 inch jacks and use two of your input channels. The computer and the mixer need to be powered from the same receptacle. The sound boards in laptops sometimes are noisy. If the above doesn't fix it, buy a computer audio interface such as a UA25EX or others. Some are available for about $70 that use a computer USB port and generate decent clean audio.
Apr 27, 2011 | Samson Xm410 Powered Mixer
Aux jack over time seems to be faultering.
sounds like the soldering points on the jack are coming loose or shorted out. The stereo will have to be taken apart and checked out. You will most likely need a soldering iron to repair the problem
Jul 16, 2009 | Sony XPLOD CDX-GT200 CD Player
Question about a Shelf Stereo System
You can use any analog Audio input out of 3 at rear of this system to listen laptop sound. Audio Cord is required to hook up and its look like red-white RCA pins at one end and other end is like headphone stereo jack for laptop. Audio Cord is available at Sony Part Center.
Hope above info will help you.
Sep 06, 2008 | Audio Players & Recorders
Tv has no sound
U CAN BUY A VCR FOR ABOUT 10 BUCKS, AND GET BOOK SELF STEREO SYSTEM THAT HAS A SET OF AUDIO INPUT JACKS, USE A PAIR OF RCA JACKS TO CONNECT THE AUDIO OUT FROM THE VCR TO THE AUDIO IN OF THE BOOK SELF STEREO SYSTEM. NOW U SHOULD HAVE SOUND
Jul 21, 2008 | Durabrand DWT1304 13" TV
GARMIN NUVI 350
HI Heather,
Make sure you don't have the sound muted. Have you tried plugging in a set of headphones into the headphone jack? If you can hear sound with the headphones, most likely, the internal speakers have failed. If you still can't hear any sound, the audio output stage on the motherboard has failed. In either case, you will need to send the unit back for repair. Be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
More Info: If you can hear sound through the speakers and don't want to send the unit back for repair, you can buy a FM transmitter at Best Buy - the kind that will allow you to play a portable CD player through your car stereo. Just plug the transmitter's audio input cable into your GPS headphone jack, power the transmitter with your car lighter jack, set the transmitter frequency to a unsued FM channel and tune your car stereo to tha same channel. You should hear your GPS through your FM stereo.
Good Luck,
- Jim
May 15, 2008 | Garmin Nuvi 660 GPS Receiver
Car Audio & Video Logo
27 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
