Question about Psi 2500 Mobile Pressure Washer 5hp Honda Engine
Engine starts but after a few seconds of spraying the engine stops. Just installed new pump
Brand new replacement pump
It won't crank up and it sat up 2 years
No gas, plugged fuel filter? Turn on the key but don't crank engine, listen with door open towards gas tank. You should hear a click and a slight motor pump noise for a couple seconds. If not then your sending unit failed.
May 15, 2016 | 2000 Ford Explorer
1985 F250 460 runs for 2 seconds but then dies
If it is a carburated engine it should have a mechanical fuel pump on the side of the engine, if this is the case it will only pump gas when the engine is cranking or running. Disconnect fuel line at carb, crank engine and see if it pumps gas out of line, if not check filter and lines from carb to tank for stoppage or bending but more than likely you will have to change fuel pump.
Feb 10, 2014 | Hayden-Harnett 1975-1999 Ford F250 Engine...
1990 s-10 4 cylinder 2.5, 5 speed, throttle body injection, 120,000 miles won't start without stating fluid. Runs fine after started, I've changed fuel pump, filter, plugs. I appreciate any help.
My first question would be is the injector spraying when you crank it ?
The way its supposed to work, the fuel line to the tank should have about 10psi of pressure before you crank the engine. When you turn the key on the pump gets power for 3 seconds to boost the pressure. The pump stops working until the engine has oil pressure which takes a few seconds.
If the base fuel pressure leaks back to the tank, or the pump relay is not powering the pump, you won't have any fuel pressure or spray until you get oil pressure.
Dec 12, 2012 | Cars & Trucks
3.5L v6 2004 kia sorento driving down road and sputtered to a stop , will start however it quits after very few seconds. if you spray fuel through air filter you can keep it running. full tank of fuel...
Hello sit in side turn key to on position do not crank engine you should hear a grunt sound like grrrrr this is your fuel pump if you do not hear this your fuel pump is not working and will need replaced .The smell your smelling is that of high either spray in your engine.
Jan 06, 2011 | 2004 Kia Sorento
I own a 1990 Jeep Cherokee Pioneer and for some reason it will not start. The fuel pump AND fuel filter are brand new but when you turn the car over it wont start. It tries to start the longer turn the key...
you have a fuel pump relay . Check to see if the fuel pump is humming when you turn key. check for proper ground for fuel pump. try spraying some carb cleaner into the intake then attempt a start. The engine will run for a few seconds, this will verify spark. corosion at the electrical connections is always a possibility. and lastly can you get the engine running by opening the throttle when starting?
Sep 05, 2010 | 1990 Jeep Cherokee Limited
I have a Hoffco Lil'l hoe and it will start for a few seconds and then stop. Last year I took it to a local small engine repair shop and they just half fixed it because a couple uses it became hard to...
Make sure your air filter is clean and you are using brand new petrol. If you left old petrol in it it may have clogged up the carb. It sound like no fuel is getting to the spark plug. If you have a rubber priming bulb, press it slowly and regularly to try and keep the engine going once you have it started on starting fluid. Good luck.
Jun 25, 2010 | Hoffco TILLER PRO HOE WITH HONDA ENGINE
1997 Jetta GT 2.0 Stopped running,cranks,will not start
Checking for spark is really simple while fuel delivery is more complicated because of the the way it is metered for delivery. On VW's a fuel pump relay is used and a jumper cable connected to relay box. This controls the fuel pump to deliver fuel manually. With a fuel pressure gauge connected to the line from the pump continued withing the system, you assess whether you have correct fuel pressure, maintain it within a specif duration. Electronic fuel injectors do stick or stay open causing very poor or no start condition. Make sure you have fuel delivery since you are positive that spark is present.
May 30, 2010 | 1997 Volkswagen Jetta
1997 Chevy Silverado 1500 4x4 will not start. Getting spark checked all fuses, changed rotar - spark plug wires,
Have you checked the fuel pressure? Fuel pumps are a common failure item on those trucks. Pick up a cheap fuel pressure gauge and hook it up to the shrader valve on the fuel rail. With the ignition on and you should have 55-65psi. Even if it's a few psi below spec it could stop the engine from firing.Once you determine the fuel pressure isn't adequate make sure you have a good power and ground at the fuel pump. If that checks out, time for a new fuel pump module. I recommend only replacing it with an AC delco unit, I've heard bad stories about aftermarket replacements.
You could also spray some carb cleaner or starting fluid in the throttle body and crank the engine over. If it runs for a few seconds after spraying starting fluid in you know you have a fuel delivery problem.
Mar 14, 2010 | 1999 Chevrolet Silverado 1500
No fuel delivery from the Brand new fuel pump and filter. 1988 Ol
The pump is only suppose to run for 3 seconds if the engine is off. It will only stay pumping if the engine is running so the circuitry seems to be just fine. You prabably just got a bad pump again. Its common for repair shop to put 2, 3, and 4 pumps sometimes before they get one that works. We find it very common that a gauge will malfunction and the real problem is you just ran out of gas.
Aug 30, 2009 | 1988 Oldsmobile Delta 88
Psi 2500 Mobile Pressure Washer 5hp Honda Engine Logo
63 people viewed this question
Top Psi Tools & Hardware - Others Experts
Tim Venetis
Mike Squire
Are you a Psi Tool and Hardware - Other Expert? Answer questions, earn points and help others
