Question about 2000 Lincoln LS - All LS models - Triguard Car Cover
Lincoln ls 2000 where do I recharge my a/c where is the part at on the car?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
There is two caps on the a/c one is smaller than the other but note if you have no Freon at all then it will need pulled down on a vacuum to check for leaks . you may need to take it to a shop. if you over charge it you could damage your a/c unit or lines.
Posted on Jul 19, 2014
  • 400 Answers
Follow the suction hose from the A/C pump back toward the evaporator. You should run into a port. Unscrew the cap and connect your charge guage. I hope this helps.
Posted on Mar 29, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Will a 3.0l engine from a 1999 mazda b3000 work in a 2000 lincoln ls
The answer is "NO"
Why would you even think that was possible ?
Mar 22, 2014 | 2000 Lincoln LS
2000 lincoln ls - where is the a/c compressor located so i can recharge a/c?
If you need to add refrigerant,you have a leak.
Repair the leak first,don't polute the atmosphere
Take it to a shop, that has people licenced to purchase and use refrigerant correctly.
May 17, 2010 | 2000 Lincoln LS
Why the ac on my 2000 lincoln ls is no working
chances are that its just low on R134 refrigerant ... .. thats the new stuff that replaced freon (R12) years ago ... R134 is a smaller molicule so it leaks out much more easily ... in many cars it has to be topped off periodically ...there are kits available (with a gage) that will allow you to top off the R134 yourself if you are mecanically inclined ... if not then professional places can test for leaks and other problems and recharge your system.
Apr 09, 2010 | 2000 Lincoln LS
Cannot find where to recharge ac on lincoln LS
The recharge valve is under the engine on the drivers side in front of the tire. you have to remove the protective plate for the compressor then you will find the valve. You might have to jack the car up to get to the plate. I didnt but i have long arms.
Aug 11, 2009 | 2000 Lincoln LS
Where is the air conditioner recharge valve in a Lincoln LS 2001
their are two ??one high and one low pressure connector and without the correct machine to re-gas do not attempt to touch anything as its extremely dangerous with high pressures and volatile gas that can freeeze a finger with frostbite in a second
Jun 21, 2009 | 2000 Lincoln LS
2000 Lincoln LS - All LS models - Triguard Car Cover Logo
Top Coverking Vehicle Parts & Accessories Experts
baire
gbob59
David Harrelson
David Harrelson
Are you a Coverking Vehicle Part and Accessory Expert? Answer questions, earn points and help others
