Sony VAIO VGN-N325E Notebook Logo
Millie Warren-Oteng Posted on Mar 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO REPLACE THE HARDDRIVE
I AM UN ABLE TO REMOVE THE KEYBOARD IN ORDER TO GET TO THE HARD DRIVE
Larry Symms
Level 2:
  • Expert 77 Answers
  • Posted on Mar 27, 2014
Larry Symms
Expert
Level 2:
Answers
77
Questions
Helped
14791
Points
208
Http://laptoprepair.ca/news/11152.html
3helpful
2answers
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
3helpful
2answers
I want to change the harddisk, but I can not get the computer opened in order to so. Any suggestions?
In order to change the hard drive on this laptop you are going to have the remove the battery and the keyboard because the hard drive is directly under the keys. When you remove the battery you will see 3 screws, remove them. Open the screen and flip the laptop over to see, in the battery compartment, the keyboard release access. Insert a flexible tool and press inward to release the keyboard. Flip the laptop over and gently lift up the top part of the keyboard until it releases. You will see you have the hard drive there. Unscrew it, remove the bracket and replace the hard drive. Be careful not to loose any screws and never force a screw back into place.
I have a hp4345mfp on the display it is showing a error internal disk not found we do not have a hard drive can we turn off the hard drive thank you my email is
All HP MFP's have an internal harddrive and will only function as printers if that drive fails. You need to replace the harddrive. It is mounted on the formatterwhich is accessed on the back. First remove the sliding panel and then open the metal door. These are right where the fax and data cables plug in. You can replace the drive with almost any 2.5" IDE harddrive that you can find. The standard model will be either a 20, 30 or 40 gig, I have installed up to 160 gig drives with no problem. Do not order a drive from HP as they will charge several hundred dollars for a drive you should be able to get at any computer shop for less than $75.00. Be cautious removing the drive from the plastic mounts as they are easy to break.
1helpful
2answers
Dell Inspiron 14R Laptop. Daughter spilled liquid on keyboard and now when i turn on laptop screen says: For Atheros PCIE Ethernet Controller v2.0.2.3 Check Cable Connection! PXE-MOF: Exiting Intel PXE...
Ya sounds like the hard drive has died or there is a interface problem since you suffered from water damage. you may be able to get data off the hard drive by using a external hard drive connector but it may or may not work.
I want to take some programmes my hard drive and use them in my external hard drive.
There are essentially two types of data that are written to a harddrive.
1. Programs (such as Microsoft Excel) 2. Data that are created by the Programs (XLS files)
In order to "move" PROGRAMS, they have to be first uninstalled from the original harddrive; then reinstalled onto your external harddrive.
In order to move DATA, simply do a copy and paste from the original drive to the new drive.
Instructions for installing a toshiba hard drive MK103GAS in a Sony Vaio laptop
Step 1 - Remove Screws Flip the entire laptop over and remove the battery.617_bottom.jpg
There are a total of 4 screws you need to remove as depicted in the red circles.617_unscrew.jpg
Begin removing one at a time.617_unscrew2.jpg Step 2 - Removing the Keyboard After you remove the four screws from the bottom chassis, flip the laptop over and take a look at the keyboard area.
Now look carefully at the top corners of the keyboard, there is a tiny little button that you need to push in order to release the keyboard. 617_keyboard1.jpg
Push both the release keys while pulling the entire keyboard towards you. 617_keyboard3.jpg
Gently lift up the keyboard towards you, while flipping it over. 617_keyboard4.jpg
The keyboard has been removed!
Step 3 - Removing the Palmrest Looking inside, you will need to remove three screws as depicted in the red circles below.617_unscrewhandrest.jpg Next, gently slide the entire palm rest chassis towards you.617_handrestremove.jpg Before you lift the palm rest, notice the delicate ribbon cable on the underside. Then lift it upwards, flipping it over. Be careful not to rip the ribbon cable that's connected!617_handsetremoved.jpgYou now have access to the hard drive!
Step 4 - Removing the Hard Drive Remove three screws from the cage holding the hard drive as depicted below in the red circles.617_unscrewthree.jpg Next, gently remove the SATA cable from the hard drive. It may require a bit of effort to pull the SATA cable from the hard drive, just try to be gentle. Note that there is tape over the SATA cable underneath the hard drive making the SATA cable more difficult to pull out.617_removesata.jpg
Be careful in this step not to rip the ribbon.
The hard drive is now removed!
The next step is to just remove the stock hard drive from its cage be removing the screws on the edges and replace it with the hard drive of your choice. Carefully screw it all back in place, slide the keyboard back in and power on your system! 617_hardrives.jpg
Replacing Toshiba 120GB hard drive 5400RPM with Seagate 100GB 7200RPM 2.5? Hard Drive.
Enter the BIOS by pushing on F2 key during the VAIO boot screen. Ensure the proper hard drive is listed in the BIOS. 617_biosscreen.jpg
Insert your Windows XP or Recovery DVD disc to begin installing the operating system!
if it help full to you please vote me
thanks:ayyunoora
2helpful
Cannot boot says cannot find harddrive nad suggests reseat drive
it could either the hard drive is corrupt or slightly un fastened
try un hooking the hard drive and firmly hooking it back again
I had a new hard drive installed on my computer and now my keyboard will not work. My mouse does, but not the keyboard. I temporarily have a wired keyboard hooked up. I can't seem to reset the wireless...
i found 2 computers in the trash. the keyboard and the mouse does not work with a hard drive in it.i cant even get into the bios. when i remove the harddrive. the mouse and keyboard works fine. what could be the problem.
2helpful
2answers
Harddrive
dr. geek is partly right:
at the bottom you'll find the 2 RAM-memory slots for the SD-RAM 144-PIN modules
(the bigger one in the center, 2 screws)
to access harddisk and cmos battery:
follow the instructions:
you will need:
a slim x-screw-driver
a sharp knife with a slim blade and
a cup or else for the screws, don't loose them!
a new c-mos bios battery model: CR-1220 (exchange it while your in there!)
you find c-mos battery and hdd under the keyboard!
- turn off the power, remove accu and charger cable, for static electricity is friendly fire
to your laptop now !
- open your screen to max. fold (angle of 180 degrees)
- look for removable plastic part near to left holder of screen
- carefully remove it
- also remove plastic panel right to it in the section between display holders
metal should be visible now
- carefully! remove keyboard, starting at the left side, continuing topside
as you won't be able to fully remove it, simply turn it over
- unscrew any screws holding the metal plate, remove it
- now you see: left the CPU plus cooler, top right middle the hdd still in an adapter attached
to the mainboard, at it's lower right the C-MOS battery (g
- turn loos these screws
- carefully remove the frame/adaptor holding the hdd
- unscrew again the adaptor
- seperate hd fram adaptor
... and gotcha!
be careful to get a proper notebook hd (samsung or such)
exchange CMOS-battery by chance
reattach new hd to frame, again carefully!
to reassamble: rewind the procedures
put everything back in place
replug, pray and turn on the lappie.
wish you luck.....
3answers
Gateway DS PROFILE 4 XL need to remove hard drive
To remove the harddrive from your desktop computer
1.unplug
2.open the pc case
3.disconnect ide harddrive cable from the hard drive
4.disconnect power cable from harddrive
5.unscrew the hard drive
6. take the hard drive out.,
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
