Question about CoverBot iPad mini Keyboard Case and Stand HOT PINK - Aluminum Bluetooth Keyboard Case with Integrated iOS Command Keys for iPad mini
The top row of keys on keyboard not working on coverbot. Any solution is welcomed
I have had a cloverbot clamshell for ipad mini for just over 4 weeks and now all the keys on the top row of keyboard do not respond. Any suggestions?
How do I get the keyboard of my Ipad mini to drop down it is stuck at the top of the page and has split in half
In the lower right of the keyboard is a keyboard key (it looks like an icon of the keyboard). Touch and hold the keyboard key. After a second or so, word choices will pop up saying something like "Dock" and "Unspilt". Touch one of the words. If you want to do both actions, repeat the process for the latter.
Feb 19, 2015 | Apple iPad Mini
How do I get my Coverbot to connect to my IPad air with bluetooth
Check your batteries in the Coverbot to make sure they are fresh. Next, make sure the Bluetooth is turned on within the iPad. Make sure the Coverbot is turned on. Click on the "Search for devices " in the Blutooth menu on the iPad. When you see your Coverbot come up, click on "Connect".
Attached is a Coverbot Youtube video, it may be of help to you. Also, attached are the directions from Coverbot. Good luck!
Nov 25, 2014 | CoverBot iPad mini Keyboard Case and Stand...
How to pair bluetooth keyboard with ipad mini?
Hi Douglas.
1. Switch on BlueTooth on your keyboard.
2. Enable BlueTooth on your iPad.
3. Search for devices on your iPad.
4. Press button if available on keyboard to get discovered.
5. Select keyboard when shown in devices list.
6. Enter pairing code sometimes 0000 or 1234.
7. Use and enjoy.
Hope this helps!
Here is the Apple site instructions:
Using Bluetooth headsets and keyboards with iPad
Here is another that explains how to do it on a MAC, might give you some clues as well:
Bluetooth How to set up your Apple Wireless Keyboard
Here is a good independent site, maybe start here:
iPad How to pair connect any bluetooth keyboard
If you prefer to watch how to do it on YouTube:
How to Connect Pair Bluetooth Wireless Keyboard to your iPad
Nov 18, 2014 | Mini Cars & Trucks
Manual
keys type all sorts of symbols,try altering the arrow key or symbol key to the left of the spacebar
Sep 03, 2014 | CoverBot iPad mini Keyboard Case and Stand...
Up wand down buttons won't work on coverbot iPad Mini keyboard case
if its nt working for ipad mini..thn software may hav been corrupted.
if the up wand down buttons totally nt working with any program or device then it may b a hardware problm!!! bttr tak it to the service center of the product.!!!
Jan 04, 2014 | CoverBot iPad mini Keyboard Case and Stand...
Hp mini 2123 Those number that attach to word always appear when ever i hit those wordingHappen this day How can i off that number
It sounds as though you have turned numbers lock on.
One of the function keys on the top row of the keyboard will, in conjunction with the function key (usually labelled "fn" and located on the left hand side of the keyboard often on the bottom row) will enable toggling between numbers lock on and numbers lock off.
Dec 12, 2013 | Computers & Internet
I cant figure out how to make the "underscore" work
The underscore key is the one after the zero key on the top row of the keyboard. Just hold down shift before you press the underscore/dash key.
Jun 19, 2011 | HP Mini 1000 Netbook
How to install MEMORY IN A IBOOK 700 G3?
Look at the keyboard, in the row of Function Keys at the top are two clips, located about an inch in from each side of the keyboard, use your fingernails to pull the clips towards you and lift off the keyboard, the memory door is located under the keyboard.
Oct 16, 2008 | Apple iBook G3 Clamshell (M2453B) Mac...
CoverBot iPad mini Keyboard Case and Stand HOT PINK - Aluminum Bluetooth Keyboard Case with Integrated iOS Command Keys for iPad mini Logo
53 people viewed this question
Top CoverBot Computers & Internet Experts
David Payne
David Payne
Are you a CoverBot Computer and Internet Expert? Answer questions, earn points and help others
