Question about HP Photosmart D110a Wireless E-all-in-one Printer Cn731ab1h
Paper will not feed into printer. Have paper in place.
  • 87 Answers
Spray a little wd40 in a on a rag and clean the rubber feed tire. Take the dry side of the rag and clean off the roller. Should feed good if not replace feed tire.
Posted on Sep 21, 2014
My dell 2350 dn feeds to much paper causing jam
Step 1: Try fanning the paper at the feed edge before placing it in.
Step 2: Ensure that the paper is placed in with the edge curl up. When holding a bunch of paper between two fingers, the paper will naturally have a curl to it. It should be placed in "happy" (Edges up).
Step 3: Inside the printer's paper tray and where the feed mechanism is, locate the feed rollers and static feed pad. These will all be rubbery or "foam"-like. They should always be slightly tacky when rubbed against, however paper dust will eventually cause them to become slippery instead. Rubbing alcohol can be used to clean them with care and a Q-tip and recover the slightly rubbery, tacky feeling, thus resolving misfeeds.
Mar 28, 2014 | Generic Laser Compatible Dell 2330 2350...
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
How to feed paper roll into calculator
Installing the Paper Roll
Caution: Avoid placing a double thickness of paper into the mechanism.
Do not pull the paper through the mechanism without pressing feed button.
1. If necessary, press on to turn the calculator on, and press P
to turn the PRINT display indicator off.
2. Remove the printer compartment cover by placing a thumb on each of the lower ridged corners of the cover. Push until the cover pops open, and lift the cover off.
3. Unroll a few inches of paper from the small roll and cut the end squarely.
4. Hold the paper so that it unrolls from the bottom, and insert the end of the paper into the slot under the printing mechanism.
5. Press feed button until the paper feeds out of the top of the printer compartment.
6. Place the small roll of paper inside the compartment.
7. Feed the end of the paper through the slot behind the clear plastic "window" of the printer compartment cover. Then snap the compartment cover back onto the unit.
Jun 07, 2011 | Texas Instruments TI-5006 II Calculator
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
32T-26.eps
1 Move the paper lever to the position marked "REAR."
32T-11.eps
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
32T-27.eps
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
32T-29.eps
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
32T-29A.eps
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
lever.
32T-29.eps
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
32T-31.eps
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
32T-12.eps
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
guide.
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
32T-15.eps
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
WILL FEED PLAIN WHITE PAPER BUT WILL NOT FEED PHOTO PAPER
Follow the steps:
•1
Turn on the printer and press the Paper Feed switch until the Auto Sheet Feeder indicator light turns on.
•2
Pull up on the paper sheet feeder on the top and back of the printer and slide out the paper support.
•3
Take a stack of no more than 10 pieces of photo paper and flatten the corners, if they are curled. Curled corners may cause jams within the printer.
•4
Place the paper in the paper sheet feeder with the printable side of the paper facing up. The printable side of photo paper is the shiny or whiter side of the paper.
•5
Print your documents as needed.
Paper Cassette :
•1
Switch on the printer and press the Paper Feed switch until the Cassette indicator light turns on.
•2
Pull on the cassette on the bottom of the printer to slide it out of the printer.
•3
Flatten the corners of a stack of no more than 10 sheets of photo paper if the corners are curled. The paper may become jammed in the printer if the corners are curled.
•4
Place the stack of paper in the cassette so the paper is touching the right side and the printing side of the paper is facing down. Adjust the plastic paper guides so they touch the paper. The paper stack guides help facilitate the paper moving into the printer.
•5
Slide the cassette back into the bottom of the printer. The printer is ready for printing.
Oct 20, 2010 | HP PSC 2355 All-In-One InkJet Printer
Paper feed not move
If I recall the KXP series, it is a track feed printer as well as sheet feed, there should be a lever on the top that you can move to different positions, one position is for feeding paper without the rollers, when the lever is placed in a different position it releases the rollers so the printer can feed the paper. The open position is for installing paper or clearing paper jams. Also if I recall, the lever is on the right side near the roller on the end. When you move the lever, and turn the roller, you fill feel it grab the paper. There is also a switch on the front for line feed and page feed allowing you to tear off a page and then pressing it again will reverse the paper to print position.
Aug 30, 2009 | Panasonic KX-P3696 Matrix Printer
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
Paper feed rolls is rolling over the paper...how to get access to those rolls
  1. Feed the paper manually into the printer:
    1. Place a sheet of plain A4 paper in the paper feed tray.
    2. Move the paper support on the left-hand side to the left end of the paper.
    3. Press the paper feed button.
    4. If the paper does not feed, continue with step 2.
  2. Check for any obstructions in the paper feed path:
    1. Disconnect the cables from the back of the printer.
    2. Open the front of the printer and check for anything that may be blocking the paper path.
    3. Close the front lid and remove any paper from the paper feed tray.
    4. Holding the printer in both hands, turn it upside down to see if anything falls out of the paper feed area. (Sometimes objects such as pens, paper clips and so on can fall into the paper feed area and cause blockages.)
You can clean with special cleaning paper which ca be used clean the rollers............
Dec 08, 2007 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x3350
Nov 20, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP Photosmart D110a Wireless E-all-in-one Printer Cn731ab1h Logo
65 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
