Question about LG LFC25760 French Door Refrigerator
Creaking noise after refrigerator door is closed
Noise occurs right after doors are closed if freezer drawer is also closed. It lasts for a few seconds. Had the fridge for ~6 months and noise just recently started occurring. Is there a damper that opens/closes with the fridge door that may be the source of the noise?
  • Andrew Krebs
    Andrew Krebs Mar 27, 2014
    An additional detail: the noise sounds like it's coming from the lower(freezer) part of the unit
  • 76 Answers
Only thing I can thing of is the slight vacuum caused by the quick temperature change when the warm air that enters when the door is open is trapped after closing the door. As it cools it shrinks and creates a mild vacuum which should dissipate after a few seconds. The creaking is probably the sound of the pressure regulating between the fridge and the room. Might indicate a problem with one of your seals but more than likely is not a concern.
Posted on Mar 27, 2014
  • Andrew Krebs
Monogram DISP480DXASS jack hammer noise behind the Climate Control Drawer.
By the way you discribe it, it sounds like it's going into defrost mode check and make sure freezer side isn't iced over or that the drain isn't iced over if it's a side by side drain should be at the very bottom of freezer side usually hidden behind a piece of plastic if it's a top and bottom the drain will in the freezer very back bottom also hidden hope this helps
Mar 04, 2016 | Refrigerators
GE profile fridge making loud humming noise
The door being open so long caused warm moist air to collect and freeze inside the unit.
Take everything out, unplug it and let it thaw out for an entire day. All the frost will thaw, and probably run water all over the place so put towels down.
When you plug it back it, it should work fine.
Jul 26, 2014 | Refrigerators
I have samsung french door refrigerator 2 door 2 drawer with vibrating a noise. I have removed the back panel and the noise does not seem to be cominng from this area. any suggestions.
We have a different model Samsung, and I've heard a vibrating or buzzing noise twice. First, if the water filter isn't an exact fit (even Samsung's filters rattle), it will rattle. Second, if either of the ice makers gets stuck or jammed, it can make a vibrating noise. If our freezer drawer isn't making a good seal, ice will build up under the drawer or in the slides. Ours makes more of a humming noise, when this happens. Other areas to check: something stuck in the runner of your drawers or shelves (if yours pull out). There are also vents that draw air in and out of the cooling unit, and things in front of them may vibrate or rattle, too.
Jul 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
JFC2087HRP Jenn-Air freezer creaking noise.
Most of the time this happen when the refrigerator has been hooked up to the water, and than you unhooked it!!, the water that is in the hose makes that sound when it's pushed by the air in the hose. that's a typical problem when you unhooked the water.
May 13, 2010 | Jenn-Air JFC2087HRP Side by Side...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Kenmore Elite Trio makes creaking/groaning sounds
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jan 30, 2009 | Jenn-Air JFC2089HE French Door...
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Trio 596.76502500 Mystery Noise
Does the noise only occur when the compressor is running ? My unit has this problem, similar symptoms to your unit, they stop when the freezer door is opened, etc., Several service calls have not completely eliminated it - yet ! The problem seems to be that the compressor coils are too close to each other and rattle. Adjusting them helps for a awhile.
Jul 31, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Strange Noise - Creaking
I had the same problem. My fridge would make a creaking sound as soon as the freezer was closed. I took 10 minutes to trouble shoot the problem and pinpointed that it was coming from the icemaker. After wondering if I was going to have to replace it, I noticed a piece of ice wedged in a way so that the ice maker arms could not fall into the basin to make ice. The sound was the motor creaking because of the jam. Removed the ice and the sound went away. Now, I'm sure the motor will **** out in a few months since it has been jammed for 2 weeks burning up the motor. Oh well. Hope this helps.
May 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
LG LFC25760 French Door Refrigerator Logo
267 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
