Jerking when driving slow
SOURCE: Fuel Filter in Freelander (replacing)
The fuel filter is located below the electrics box, half way between the battery and the bulkhead on the passenger side, under the bonnet. It is very difficult to see how it all fits, but it has a central screw which holds the plastic filter housing/mounting in place. Find this screw (which is a small self tapper) and be prepared to loose it, or use a magnetic screw driver. Then lift the plastic housing up and away, (towards the engine) be ready with loads of rags to catch the diesel fuel when you disconnect the pipes. There is an earth wire attached to the housing also. (anti interference, I think) It is quite a fiddle getting it back again, as it has two locating lugs on the back of the plastic housing/mounting.
SOURCE: hi i have a land rover freelander 00.back door
you have to unlock the door with the remote and then pull the handle and the window will lower about an inch and then the door will open
SOURCE: 2004 Land Rover Freelander - Engine Shakes
Hydraulic lifters? I have been racking my brains for this one. Lifters will sometimes pump up when cold and then lose pressure as they get worked. Would explain why your camshaft died. Suggest you look at old camshaft, see the cams that were worn and replace those lifters. Only thing I can come up with!
SOURCE: 2002 Land Rover Freelander radiator and air fan not working
there is a module mounted on the fan shroud that is a common problem. but as always, check fuses, connectors and grounds!
