Question about Vehicle Parts & Accessories
Location of the chassis ECM on a 2004nissan quest
Electronic devices not working properly
    Master:
  • 373 Answers
Have alternator tested
Posted on Apr 04, 2014
On my 2001 Nissan Quest 3.3L #5 cilynder miss fire replace sparkplugs, wire, distributor, and injector still miss fire so I hook a noid light to it, it won't light up at all can it be the ECM and if you...
I don't know where it is, probably under the passenger side dash. But before condemning the ECM, check the wiring to that injector. First try to determine if it is the power wire or the ground wire for the injector which is lost. With key on, the yellow power wire should have voltage on it at the injector connector. This is independent of the ECM-only the ground wire goes into the ECM, to be internally grounded to pulse the injector. The #5 ground wire is a yellow-green wire.
If you have voltage on the power wire to #5, key on, then we know either the ground wire is bad (broken or open) to the ecm -or the internal ground for that injector is out, inside the ECM.
To determine whether it is the ground wire or the ECM, you will have to locate the ECM, pull the electrical connector off to it (Be sure and take the negative battery post off, first.), then locate the yellow green wire at pin #106 of the ECM electrical connector. Now test the continuity of that wire from the injector connector to the ECM connector-use a voltmeter set to ohms. If the wire has continuity, then the ECM must have a problem- the internal injector driver for #5 may have failed. Also look for a bent pin at #106, or anything amiss in the electrical connector. In most cases, it is not the ECM but a wiring problem.
Good luck. To locate the ECM, register for free at autozone.com, listing make, model, and year. Look under "repair guides", then component locations-it should tell you the location of the ECM.
Oct 04, 2014 | 2001 Nissan Quest
2004 pcm location
under left side in the dash
Mar 27, 2014 | 2004 Nissan Quest
How to replace a high pressure power steering hose on a 2004nissan quest
parts store can give a step by step on this ask for a printout..
Feb 24, 2013 | 2004 Nissan Quest
Knock sensor 1 in Nissan Quest 1999. Where is it located?
your local auto parts store can give you your specific information, as can the parts desk person at your local dealership, by looking it up in an electronic component locator manual
Sep 04, 2010 | 1999 Nissan Quest
Location of ecm on 2004 honda pilot.
The PCM is located in the center of the board in the bottom
Jun 22, 2010 | 2004 Honda Pilot
My garmin quest will not come on even when powered by the car cradle. It flickers for a brief second, then fails.
This sounds like an old battery that has deteriorated to the point where the external power won't even turn the unit on. I have a fairly detailed description on FixYa of how to replace the Quest battery. Search for something like Quest Battery. It does involve opening the unit up. If you are not comfortable with the inner workings of electronic equipment, you will need to return it to Garmin.
Apr 06, 2010 | Garmin Quest GPS Receiver
How do I fold a maclaren quest pushchair?
You need to locate the lever standing out proud on the right hand side of the upright legs of the chassis, push this down with your foot, then push upwards the back folding section (referred to as a 'band-stand') with your foot, the stroller will then collapse by pushing this forward away from you.
Hope this helps.
Apr 05, 2010 | Maclaren Quest Stroller Standard
Vehicle Parts & Accessories Logo
24 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
