Question about True Refrigerated Sandwich Prep Table 72" 30 Pan
Freezing every so often this unit freezes up and everything that is in it..ie..ingredients that are in the inserts that sit on the top as well as everything else that is in the bottom of the unit
    Novelist:
  • 112 Answers
Keep the prep top table pans covered when not in use. Never leave empty holes where pans should be. If the pans are empty put a couple of inches of water in them to keep some heat load there. Check the door gaskets and door seal on the base doors. Make sure the thermostat is set on number 5. If all of this checks out probably need a new thermostat, but if it's erratic I suspect you will find it's one of the former problems.
Posted on Mar 30, 2014
Can I freeze hors d' oeuvres with cream cheese wrapped in flour tortillas?
I would say "yes".
Things that don't freeze well, according to Deborah Taylor-Hough, author of Frozen Assets: Lite & Easy (Champion Press, 2001), are egg-, milk- or cream-based sauces, instant rice, raw salad ingredients, dishes with dried toppings (store the toppings separately), mayonnaise unless it's mixed in and used as part of a sauce, cottage cheese, hard-cooked eggs and fried foods, which will lose their crispness.
The key is how you store and freeze them...go to the attached link:
Frozen assets Have appetizers waiting for unexpected guests
Mar 01, 2015 | Cooking
My pizza prep-table freezes everything. I think it might be the thermostat. Could I be right
Hi
Sounds like you are correct, unless the door seals are not in good order, air leaking in can fool the thermostat.
If it has a top section that the pans for pizza ingredients sit in check that the airways are clear and that the tins and lids fit properly.
Regards
Gordon
Apr 27, 2011 | True Refrigerated Sandwich Prep Table 72"...
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice cream not firm
The freezer bowl is sensitive. Go ahead and thaw it out until you can hear the liquid swishing around inside - usually letting warm water run through it is sufficient for thawing. Then refreeze the bowl, making sure the bowl is sitting flat/level in the freezer. When making ice cream with this unit, letting the freezer bowl sit out for even 20 minutes can unfreeze it enough so that you only get sludge. Do not remove the freezer bowl until you are immediately ready to pour the ingedients into the bowl. You can even pre-chill your ingredients by letting the ingredients sit in the freezer for about 15 minutes - although I have found that this usually has the opposite effect of what you have just experienced --> the ingredients usually freeze up so fast that the mixing paddle is no longer able to turn.
-Tha Mp3 Doctor
Mar 16, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
not freezing icedraem is an issue, bread not so much, different breads contain different ingrediants that may or may not freeze, forst offthough wher is unit located??? in garage??? if so be aware that it may not operate efficiently ion ambient temps lower then 55 degrees, but if this is in your kitchen i would suspect a "refrigeration"/sealed system issue, perhaps "low on charge and not able to maintain a frozen set temp. Meat may stay frozen ( for a little while anyway, but the ice cream is the first to show indications of problem
Jan 11, 2009 | Freezers
New rivl icecream maker
Hi Sunshine!
Here is a recipe from: http://recipes.lovetoknow.com/wiki/Category:Ice_Cream_Recipes
Ingredients for Vanilla Ice Cream, No. 2
  • 3 cups cream
  • 1 cup milk
  • ¾ cup sugar
  • 2 teaspoons vanilla
Instructions
  1. No. 2 Recipe, Whip two cups of the cream; to the thin part that drains from the whip add 1 cup of cream and 1 cup of milk, the sugar, and scald thoroughly.
  2. Cool and add the flavoring.
  3. Freeze till soft mush, then add the whipped cream.
  4. Turn the freezer as fast as possible for five minutes; remove dasher, repack and let stand thirty minutes before serving.
I remember sitting on Grandpa's old hand-crank ice cream maker
as a kid, holding it down for Grandpa! Add ice to the maker in about 4" increments, layering in between with a good sprinkling of rock salt (lowers the freezing point of water, so the saltwater solution is actually below freezing), crank until the motor won't turn, then CAREFULLY remove the paddles (DON'T CONTAMINATE the ice cream with the brine solution!) cover the top with plastic wrap or wax paper and let it "firm up" for 15-30 minutes. Then enjoy a great old-fashioned treat!!! Hope this helps, let me know how it goes, and good luck and happy eating! -WB
Jun 12, 2008 | Rival 8704 4 Quart Ice Cream Maker
Freezer bowl not frozen!
Preparing the Freezer Bowl:
The freezer bowl must be completely frozen before you begin your recipe. The length of time needed to reach the frozen state depends on how cold your freezer is – for best results, place the bowl to the rear of your freezer where it is coldest. In general, freezing time is between 6 hours and 22 hours. To determine whether the bowl is completely frozen, shake it. If you do not hear liquid moving, the cooling liquid is frozen. For the most convenience, leave your freezer bowl in the freezer at all times so you can take it out any time for immediate use.
Features and Benefits:
  • Freezer Bowl – The double insulated freezer bowl contains a cooling liquid between the bowl walls to create fast and even freezing. In general, the required freezing time of the bowl is 6 to 22 hours before use. Additional freezer bowls are available separately for making double batches or different flavors without interruption. For additional information on preparing the freezer bowl for use, please see below.
  • Base and Motor Unit – The base contains a heavy-duty motor that is strong enough to handle everything from thick, rich ice creams to smooth frozen yogurts to slushy frozen drinks . The base unit features a generously sized on/off switch, rubber feet to prevent slipping and keep the unit stationary while in use as well as cord storage to keep counters neat and safe when the unit is not is use.
  • Lid with Ingredient Spout – The easy-lock, transparent lid secures to the base with a simple turn, allowing you to watch the freezing process as it progresses. An ingredient spout at the top of the lid is generously sized for pouring in ingredients and ideal for adding nuts, fresh fruit, candy pieces and more without interruption the freezing cycle.
  • Mixing Arm – The mixing arm mixes and aerates your frozen desserts and drinks, incorporating and blending all ingredients thoroughly.
  • Instruction/Recipe Book - The included instruction and recipe booklet helps you get started with over 30 recipes and variations for ice creams, sherbets, sorbets, frozen yogurts and frozen drinks.
  • Feb 29, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
    Refrigerators Logo
    164 people viewed this question
    Top True Refrigerators Experts
    Dennis Boxerman
    John Tripp
    John Tripp
    Are you a True Refrigerator Expert? Answer questions, earn points and help others
