Replacement laptop screen is very dim
I installed a replacement screen and it is very very dim..
  • 2 more comments
  • Larry Symms Mar 27, 2014
    which part number(s) did you replace? Could be the backlight is failing, the ballast for the backlight is failing, or the new screen is not right.
  • Pat Holt
    Pat Holt Mar 27, 2014
    I did a bit more research and ended up ordering a new inverter board. I am hoping that will work. I was very careful in ordering the replacement screen so I know it is correct. The laptop (Dell Studio S15-158b) took a very hard fall when the screen cracked.
  • Pat Holt
    Thanks for the follow up Larry. I will post next week after I put the new inverter board in. Meanwhile, if you can steer me toward a guide specific to my laptop showing recommended method for screen replacement, I'd be grateful. It's my first install of a screen. I *think* I did it right..all connections firmly seated. But there is a loose ribbon cable coming off the back of the screen and I have no idea what it is for. The original had it too...sort of folded up and not really connected to anything...
  • Pat Holt
    Pat Holt Mar 28, 2014
    The loose ribbon cable comes off of the back of the new screen on the bottom. It has no connector on it. The old screen had the same thing and it was folded up behind the screen and the laptop case. When I removed the old screen that cable withoit a connector did nit appear to be connected to anything. There are two ribbon cables coming from the laptop. One is the wide video cable that connects to the connector at the top of the screen. The connects to a connector at the top of the laptop case where the screen is inset. Do you know where I could get a manual showing instructions specific to the Dell S15-158b?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Hi, did you connect that loose cable on your first install? that is the LCD display cable.
thanks
Posted on Mar 28, 2014
  • 4 more comments
  • Pat Holt
    The loose cable has no connector on it. It comes from the bottom of the new screen. It is a thin ribbon cable. The old screen had the same thing. I dont believe it was connected to anything...
  • darkstorm357
    darkstorm357 Mar 28, 2014
    i hope this will help you.
  • darkstorm357
  • darkstorm357
    Add a Commenthttp://www.lcds4less.com/laptop-lcd-removal-instructions.shtml
  • darkstorm357
    somehow..
  • darkstorm357
    in common cases, dim lcd is causing by faulty inverter.
Replace a screen
you replaced with the wrong screen,check the part number of the previous screen with the one you installed.part number is behind the screen near the connector
Mar 27, 2014 | Computers & Internet
Laptop screen dim - impossible to see display - computer starts up normally.
there should be a row of buttons up near the base of the screen. you have to go to the screen menu and you need to reset it to the main settings. if that don't work then you need to go to the control panle and reset the settings in the apperence section.
Dec 09, 2010 | Fujitsu Siemens Computers & Internet
Mylaptop screen keeps dimming then going bright
I suspect the backlight power of your monitor. Try to find out if the dimming is indepented of the angle of the monitor (e.g. just the time that the screen dimms out open or close SLOWLY the screen). If that is correct there is a problem (cut) in the internal cable that gives power for backlight at your screen. Reply by post.
Stelios.
Feb 23, 2010 | Computers & Internet
I have a toshiba a45-s250. the screen is dim but
Have you adjusted screen brightness control as I have seen lots of Laptops with the screen brightness control "bumped" to min.!!!
Nov 20, 2009 | Toshiba Satellite A45-S250 Notebook
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
I have a Dell laptop D505. The laptop powers up but the screen display is very dim. I can't see the image on the monitor. I've tried to manually increase the color/brightness button and nothing changes. ...
Sounds like your inverter or your backlight is failing. The inverter is an easy repair, the backlight can be replaced but it involves taking the LCD panel apart, The backlight comes installed on new screens. I can include a service manual below and possibly a generic guide to backlight replacement....
http://support.dell.com/support/edocs/systems/latd505/sm/display.htm#1052500
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Sep 23, 2009 | Dell Latitude D505 Notebook
I have a dell latitude c400 my screen is dim. However I am able to use an external monitor.
If the screen is dim and and external monitor works, then the LCD backlight has failed. Replacement LCDs for that model are around $100 on Ebay and take 30 minutes to an hour to install depending on your skill level
Jun 06, 2009 | Dell Computers & Internet
Compaq Evo N610C Faint Screen
Usually it's the inverter. Sometimes it's the backlight / lcd, and occasionally it's the lcd cable and or video card.
Easiest thing to do is order a replacement inverter from ebay. They're cheap and then swap it. You just need to remove the outside lcd bezel, it's just four or five screws and you're in business.
Feb 22, 2009 | Compaq Evo N610C Notebook
Screen burned out?
try in bios 1st adjust screen britness maby the main one is down if not try to buy just screen sumware online install new one yourself aint to hard
Jan 24, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
