Question about GoVideo DV1130 DVD Player/VCR
Just wants to play dvd
I dont want to hook up to tv, just want to play dvd and cd
I need to know how to hook up DVD player with Cable TV I have the cable with the white yellow and red. I hook one end into the TV and one into the DVD player. I don't get a pic or sound. I do not havethe...
The key is having at least a Universal Remote ($10.00 or less) that will operate your brand of TV. Your TV is only looking at "stations". You need to make it see Aux-1, Aux-2, or Line In mode. BUT, another trick is to run the DVD into your VCR (if capable). Select the VCR proper "input mode" (Aux-1, Aux-2, or Line In mode) then the DVD will play through the VCR and it will play through the TV on either channel 3 or 4. Problem solved!
Jun 27, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
ALPINE CVA 1003 AND A DHA 5680 DVD/CD CHANGER
you have the amp remote wire hooked to the power antenna lead instead of the amp wire on the deck otherwise just hook it to a switched +12 volt source. You sure you got a DVD changer instead of just a cd changer
Mar 02, 2009 | Alpine CVA-1003 Car Video Player
Will not play what i have recorded
Maybe it the problem that u dont close the session on the CD/DVD. Finalize the CD of DVD and u can play it on every DVD/CD player
Jan 08, 2009 | Cyberhome CH-DVR1500 DVD Recorder
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
Feb 26, 2008 | RCA RT2350 System
Hooking my tv to the bose
u wann hook up this unit so it plays muci throw biiggger bos system > doesnt big system have cd player this cd only not tv dvd unless it says dvd now then use outputs on back to tv input but i think it only cds
Feb 02, 2008 | Bose Wave Radio
KENWOOD KA-691 AMP. HOOKUP
ok well rca cables does your amp have all the inputs u need video 1 2 tv cd dvd ect run casete deck play out to tape in on amp cd to cd dvd to dvd rca cables unless u use coxail digital ok now the eq only has 1 in put unless u wann run itthrow a pre amp out and in if amp has that sum dont if not pick 1 or 2 to run into eq on ther own chs then back out form eg into tape 2 monitor in ok or whatever u want so u rember what ch thats on vcr run red white to video in sterio only and s video to tv or yellow comsite vcabel ok does that help
Jan 17, 2008 | Audio Players & Recorders
Tranfer mini cd to a normal cd?
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
Jan 10, 2008 | Panasonic VDR-D200 DVD Camcorder
Connect dvd/cd player to GE OR OTHER BRAND TV
if you dont have the audio video imputs RCA jacks on your TV, you can hook it up through a RF MODULATOR you can hook up to any tv this way. they come with instructions as well as the magnavox also shows how to hook one up.
Dec 10, 2007 | Coby DVD-207 Portable DVD Player
Need help with the system
Did you connect your TV to the DVD player via video cable (S-video, composite, or component)? That might be why you cant see the screen and stuff. To connect to TV, just connect your VIDEO OUT on the dvd player to the VIDEO IN on your TV. About that sub...you can hook it up, but it will only have as much punch as the player will allow. In other words, dont expect much out of a 20" sub if you have a 100 watt system.
Jun 11, 2007 | GE GTD120 System
GoVideo DV1130 DVD Player/VCR Logo
13 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
