Question about Cell Phones
What time is the skate box hours open and close bowling green ky
I just need to know for my party
5 Suggested Answers
SOURCE: instructions breville party time ice cream maker
too late now, it has thawed. Throw it out or give it to the cat.
Posted on Apr 23, 2008
SOURCE: tascam 4288
I can tell you some about it what would you like to know
Posted on Sep 29, 2008
shastalaker7
  • 1515 Answers
SOURCE: Starts to run. Then pops CB in about 2 seconds.
Hi, when a circuit trips that quik, it indicates a dead short somewhere or even a motor drawing way to much amps for the breaker to handle. If this heater is a forced air type, try and find the wiring that controls the blower motor and disconnect it for just a few minutes to test it. You may want to do this with other control componants one at a time, just by- pass each one by unplugging or disconnecting each one and start it. If the breaker holds when you do this, you will then know which part is causing the breaker to trip. Keep me posted on your progress.
Shastalaker7
Posted on Jan 19, 2010
heatman101
  • 43501 Answers
SOURCE: can i use th5320u1001 on
Yes, that t-stat has that capability...
http://www.pexsupply.com/Honeywell-TH5320U1001-The-FocusPRO-Non-Programmable-Digital-Thermostat-Premier-White-4956000-p
If you need the manual to get it set up then check out this tip...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Posted on Sep 15, 2010
Why is my Next book Premium 7 SE is not holding a charge. Loose connection. I have a 2 yr. warranty but cannot find my paperwork. Purchased at Walmart Bowl Green KY. 2012
Tablets use Li Ion batteries. These batteries have what is known as a "memory" if the devices are allowed to drain all the way, this often damages the battery.
Not charging the battery for a full 8-24 hours can also cause the battery to hold a lower charge. For example, when it says "Please put device on charger" you charge it only till it says full then remove (usually a 1 hour to 4 hour charge). This is not an actual full charge and can also damage the batter / cause it not to hold a long charge.
The battery can be replaced, and are usually not very expensive. The last tablet battery I replaced was about $15.00 for the battery itself. Some are a little cheaper.
Most repair shops should be able to perform the repair if the warranty paper can not be found.
Dec 01, 2014 | Computers & Internet
Still wont print after head cleaning
if the printer is not used for a long time likely clogged printer ad cartridges dry or remove the seat cartriges.Put in a bowl with rubbing alcohol (about 0.5 mm tall on the boat) put there party cartridges let there Let them in 1 / 2 hours or even an hour. (the same can be done with cariage, if you're good to disassemble it). if no results will be opened to the printer, ink clean pump, Sloppy as the entire route print
Mar 29, 2011 | Epson Stylus CX4800 All-In-One InkJet...
Can i use th5320u1001 on 2 stage compressor and 1 stage heat? tom roll , abe service company , bowling green,ky
heatman101
Sep 15, 2010 | Honeywell Electronic Programmable...
Starts to run. Then pops CB in about 2 seconds. Ignition is OK. I think it momentarily lights off. REDDY HEATER made by DESA of Bowling Green, KY
Shastalaker7
Jan 18, 2010 | Reddy R155D Utility Heater
My cell phone drope in water.what cain i do to have my phone?
TAke it apart, put all of the pieces in a covered bowl of uncooked rice for 48 hours, and then try to turn it back on
Apr 22, 2009 | Samsung SGH-X160 Cellular Phone
Need to Know how long it take to charge Battery
2.5 Hour Battery Life - Average of 4 Hour Charge time (To ensure longest battery life possible)
Closest Manual Information - Here That manual is through a 3rd party, as the company is no longer available online.
Mar 13, 2009 | Protron PD-007 DVD Player
Xerox Documate 252, just quit working
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power
saving and preparing to scan.
• Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252
1. Right-click on the One Touch icon and choose Show
Hardware from the pop-up menu.
You can also click the scanner icon at the top of the One Touch
Button Panel.
If the Hardware View of the panel is open you can also right-
click on the DM252 icon.
The Hardware Properties dialog box opens and shows
information about your Xerox DocuMate 252 scanner.
2. Click the Properties button.
Your scanner has a built-in power saving feature that is set to
power down after 15 minutes of idle time. You can change the
time before the scanner powers down, from 1 minute to a
maximum of 3 hours.
3. Click the arrows for the Lamp timeout setting and choose a
time setting.
To return the scanner to its factory settings, click Reset Device.
4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Dec 09, 2008 | Xerox DocuMate 252 Path-Through Scanner
Tascam 4288
Sep 28, 2008 | Tascam 2488 Portastudio Multitrack...
My trany not shifting
I had the same problem with my1994 3-speed. I whent back and took both clutches apart and found a gasket that had not been seated properly and replaced it. workes fine. The lip of the gasket wouldn't go into the place it should. I assembled the disk put on ky jelly for lube and found a glass bowl that was about the same size. Putting the disk with with the gasket lip side down in the bowl so that the gasket was held very close. It was then in the same position as it should be when assembled. I then put the bowl in the freezer for an hour. when I took it out it stayed in the proper position. I just dropped it into the clutch assembly. Fit perfect no problem. Dan
Jul 12, 2008 | 1991 Dodge Caravan
Instructions breville party time ice cream maker
Apr 20, 2008 | Blenders
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
