Question about Kenmore Dehumidifiers
Idylis dehumidifiers information
Idylis dehumidifiers. Any recalls?
U can find out here: https://www.cpsc.gov/Recalls/2017/Gree-Reannounces-Dehumidifier-Recall-Following-450-Fires-and-19-Million-in-Property-Damageb
Mar 23, 2017 | Dehumidifiers
I have a idylis dehumidifier and a part that connects to the hose broke (part number WDH-1670EA) where can I purchase another one and what is the name for the part. Thanks
TERMS OF WARRANTY Plastic parts, are warranted for thirty (30) days only from purchase date, with no extensions provided. First 12 Months: During the first twelve (12) months, any functional parts of this product found to be defective, will be repaired or replaced, at warrantor's option, at no charge to the ORIGINAL purchaser. To obtain service: Call 1-800-643-0067 or RETURN TO THE STORE WHERE PURCHASE FOR REPLACEMENT. http://pdf.lowes.com/useandcareguides/840206120030_use.pdf
Jun 27, 2015 | Dehumidifiers
Idylis 0526051 dehumidifier - ice build-up. After 7 months of use this started to make a laboured noise that was audible the floor above. I switched the unit off and noticed what appeared to be a "check...
Dust and dirt that causes loss of airflow through the coils is the most likely cause. The only other reason would be a low refrigerant charge to the compressor.
Dec 26, 2014 | Dehumidifiers
IDYLIS 052605 dehumidifier will not shut off when the desired humidity level is reached The machine just keeps running.
well does the unit continue to make water in bucket, the reason i ask is that some units have an air circ fan that runs all the time reguardless of setting this is how its designed
Oct 05, 2014 | Dehumidifiers
Idylis dehumidifier 0526011 will not shut off even when is reaches it humidity level. How can I get it to shut off. The compressor stops but the fan keeps running.
this is a newer feature that a lot of units do now this is called air circulation mode !! try running on low it's not so noisy then
Oct 03, 2014 | Dehumidifiers
How do you set on and off auto
See page 7 on the user manual to set the humidity level and the unit will then operate within the set humidity range. You can also set the timer to make it shut off automatically after a specific time. You may also need to install the continuous drain feature if you do not want to empty the water tank repeatedly.
Aug 06, 2014 | Dehumidifiers
Need manual for idylis 0526011
here is the manual: http://pdf.lowes.com/useandcareguides/840206120030_use.pdf
Jun 16, 2014 | Dehumidifiers
Idylis 0526011 does not work
SET IT TO LOWER SETTING
Mar 07, 2014 | Dehumidifiers
Dehumidifiers Logo
395 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
