When i turn on my xbox, two red light alone with two green light flash around the on button. Has anyone seen this before? Does anyone know how to fix it? Any help would be appreciated. thanks
Two blinking red light's on the power button means that your console has
insufficient ventilation. The red light will continue flashing until the
console cools down.
Let your console cool
Turn off your console.
Let your console cool for one hour.
Turn your console back on.
If the solution worked, your power button should be green.
If your power supply cords are not plugged in securely, you may see one
flashing red light when you turn on your Xbox 360 console.
Check out this site and follow along according to the symptoms face by the xbox360.
Hi when the power button flashes red if you hold down the little round white button under the dvd tray and keep holding it down then press the open button for dvd then it will flash a number of lights write this down. it will be flashing 1 2 3 or 4 lights so write it down then hold down the white button again and press the draw open button again and write down how many again. do this 4 times all together and tell me what code it has given you then i can tell you exactly what the problem is
so for instance you hold down the little white wireless button and keep holding it down then press the open button for the dvd tray and say 4 lights are flashin so write down 4 then hold white button down again and press open button again it may flash 4 again then do it again and it may flash 2 lights then again and it may flash 2 again
when you have gotten these 4 codes post me a message and tell me exactly what they tell you and in the correct order so it may look like this 4 lights flashing 2 lights flashing 1 light flashing 2 lights flashing
if you look at where the button is where you turn it on well you have the green light in the middle well around this is four outer lights that light up red their are 4 of these 2 at the top and 2 at the bottom either side of the green light, their the ones that flash green when its spinning rounf with green lights so write this code down then ill be able to tell you exactly what the fault is ok
When only 1 of the 4 green lights that are located around the start button flashes red and the screen flashes an error code number, it means that you've got the Xbox 360 1 red light message.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
once you have found out if its the hard drive or the dvd drive then this is the part that needs replacing. you will either need to get someone to do it for you or if you have some idea what you are doing then it is something you can do yourself, always check to see if you have any warranty left and if you do take it back if not then you will need to pay someone to do the work for you.
if you are doing it yourself then take it from me its not easy taking the case off let alone changing the parts so if you are going to do it yourself use google and fine an xbox 360 repair guide and this will then give you step by step instructions on taking the case off and removing any parts you need to remove
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable. Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port. Solution http://support.microsoft.com/kb/906652
If you have 4 lights, check your A/V cord. 3 lights is the Red Ring of
Death. Call Microsoft. They have an extended 3 year warranty for this
problem. hope this helps AJ
turn on the console. let it start up all the way. turn on the controller. on the console to the right side of the two memory card slots is a little button. press and hold it til the green lights start flashing around the power button. there is a little button on top of the controller. when the lights around the power button are flashing, press and hold the button on the top of the controller til the lights around the center button start flashing and then it should sync together
got to e bay theres a guy on there selling plans on how to fix the three red lights will save u a lot of money as u wood have to send back to microsoft 4 fixing and its about £25 p&p the the repear on top then p&p back to u hope these helps e mail me if u need more info [email protected] thanks
