Question about Canon 75-300mm f/4-5.6 III USM EF Lens
I bought Canon EF 75-300mm III Zoom Lens, but the len is very loose, is it problem
I bought a used Canon EF 75-300mm III Zoom Lens,but the len is very loose, is that problem
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
Long and short of it...if the photos are close to "decent", dont worry bout it :) It aint no L Lens but can still throw out a good pic every now n then. Tip it from one end to the other whilst holding it...if you hear something go \'ring-a-chicka-chink-chink-clunk\', then youve got problems, otherwise grin and bear the looseness - mine lasted 6 years of hard yacker before i dropped it in the drink!
Posted on Mar 27, 2014
cammedic
  • 667 Answers
SOURCE: I have a Canon EF 300mm f/2.8L USM Lens
Here is a link to many Canon products in PDF form: Canon Parts Lists
Unfortunately, the only 300mm 2.8 lens listed is the IS version
The procedure is not that complicated, but you need to pay attention to the connections on the circuit board. The mount is removed, and you need to remove the small screws that hold the connector board to the mount ring first.
I cannot do live chat due to I use a Mac, but I will monitor the thread if you have questions,
Kevin
Posted on Mar 24, 2008
SOURCE: EF 24-70 lens droop...
The zoom creep is an easy fix for Canon. I really do not recommend trying to tighten it yourself, since that would void your warranty.
It is usually free to tighten the zoom ring.
/Chris
Posted on Jan 19, 2009
  • 130 Answers
SOURCE: Water inside the lens (Canon EF-S 17-85mm F4.5-f5.6 lens)
if it is only fogged you can blow hot air on the lens while fully zoomed in and after the water has evaporated, zoom out to compress the moist air out. do this several times.
Posted on Jun 13, 2009
weixun
SOURCE: Canon EF-S 17-85mm - Stuck Zoom
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens. Canon has no respons with it problem and ask you send to their quick fix store for repair.
Posted on Nov 26, 2009
Obertelli
  • 3006 Answers
SOURCE: Canon Zoom Lens EF-S 17-85mm 1:4-5.6 USM: I
I hate to re-invent the wheel (and I don't want to cut 'n paste someone else's hard work to present as my own) so please click here for a likely practical solution which usually works and for Canon's own suggestions on the error 99 fault.
If this has assisted you then please rate my answer; if not then add a comment to provide feedback and I'll attempt to provide an alternative solution.
Posted on Mar 02, 2010
Very loose lens 75-300mm canon zoom
If it is loose on the camera mount, try to avoid using it. If it causes your camera mount to distort, then you won't have much luck with any other lenses!
If it is "loose" meaning: it rattles and there's a bit of play in the 'barrel'...yuuup - get used to it. She's an oldie but a goodie.
Oct 24, 2013 | Canon 75-300mm f/4-5.6 III USM EF Lens
My lens is really loose when I zoom out , how can I fix it, I have a canon ef 75mm to 300mm
There's a screw located on the barrel of the lens. This may help tighten things up, but don't count on it. Don't try to take it apart unless you know what you're doing. There are a series of sleaves within the barrel which need to match up and you might have to fork out more than the lens is worth just to get it fixed
Oct 16, 2013 | Canon 75-300mm f/4-5.6 III USM EF Lens
Does my Sigma 28-105 mm Aspherical for film camera work on my Canon 5D Mark III?
If the Sigma lens mount is a Canon FD fitting then you can get an adapter FD to EF that will allow you to use the old lens in manual mode. If your camera isn't designed to take EF-s lenses then they will not fit on the camera. My EF-s lenses will not fit on my 6D.
Jul 24, 2012 | Canon Cameras
Ribbon cable of lens is broken of Canon Zoom Lens EF 75-300mm f/4-5.6 III
This is a simple and relatively inexpensive repair. Take it to a reputal repairer.
Apr 28, 2012 | Canon 75-300mm f/4-5.6 III USM EF Lens
Canon 17-85 IS zoom ring locked at 17mm.
Sometimes, if that lens has heavy use or if it has been traveled with a lot, several of the internal zoom screws may come loose deep inside the lens and cause the zoom to freeze. It requires a complete disassembly of the lens to reach the screws and re-seal them so it does not happen again.
Bob Kilbourn www.camerarepairs.com
Aug 08, 2011 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Best telephot zoom lense for my canon 1000d
That's a decision only you can make. What's most important to you? Long focal length? Wide zoom range? Lens speed (maximum aperture)? Weight? Cost?
Also, what do you want to do with the lens? The best zoom lens for taking wedding pictures is not necessarily the best zoom lens for taking sports pictures.
Jan 25, 2011 | Canon 75-300mm f/4-5.6 III USM EF Lens
Can u tell me how i fix error 99 of canon zoom lens 75-300mm
This article will lead you through the steps to identify the cause and a possible fix for this error.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Oct 12, 2010 | Canon 75-300mm f/4-5.6 III USM EF Lens
New Camera
Get the Canon EF 70-300mm IS USM about $500 and EFS 17-85mm IS USM about $300. The 75-300 all of them I would not use them 4 a body cap. Camera is fine or step up to XSI.
Jun 10, 2009 | Canon Zoom Telephoto EF 75-300mm f/4.0-5.6...
/Chris
Dec 13, 2008 | Canon EF 24-70mm f/2.8L USM Lens
Canon EF 75-300mm f/4-5.6 Repair Manual
Mine had the same problem. The electric flexible wire that links to the moving aperture motor in the center is most likely broken, causing the aperture to stop reopen after a shot. this could be proved if you feel something touching inside when zoom. (that is caused by the loose flexible wire, if so do not zoom anymore, you could further damage the wire) It need to be replaced and this requires the complete disassmebly of the lens. I repaired mine myself by adding a thin wire, took me more than 10 hours in total (first tear it apert, pin point the problem, then think of a solution because I did not have the parts for repair, then finally repaired it). If you have never done lens/electronic repair before, don't do that, too many tricks that could lead to further damage.
Mar 17, 2008 | Canon 75-300mm f/4-5.6 III USM EF Lens
Canon 75-300mm f/4-5.6 III USM EF Lens Logo
124 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
