Question about Thomson TSR200 Satellite TV Receiver THOMSON
Thomson tsr200 pin code reset
How can I reset the pin code?
I need thomson scenium 32wf64 s remote code for a universal remote (the remote only does 3 digit codes)
Your universal remote probably has a code search feature which you can use to find a code that will apply to your Thomson TV. If a search through all codes stored in the remote fails to work, you may have to try another universal remote.
Jan 03, 2015 | Thomson Televison & Video
Forgot pin for thomson box
Refer its user manual for details. If you haven't the user manual with you now, try this link to download it. http://www.manualslib.com/manual/545750/Thomson-Tsr200.html
Mar 27, 2014 | Thomson TSR200 Satellite TV Receiver...
Wireless pin thomson refuses connect
make Hard reset , 1) disconnect the power cord 2) Press the small hole in your modem-router by 45 seconds.
Then try again,proceed with the reverse steps.
God bless you
Nov 26, 2013 | Computers & Internet
Tv thomson black screen
this a problem from Raster, coming from HV flyback, rectifiier, horizontal output, and circuit from HV. repair.or go to the repair shop TV for fix it.
However you must reset the code, download from www.fitness.manualsonline. com or memorex.com or www. remotecodelist.com and try it again.
God bless you
Jul 22, 2012 | Thomson RCT311DA1 Remote Control
THOMSAN TV ( USE REMOTE CONTROL ) WHAT HAPPEN , CHILDREN SOMETHING DID , TV DID NOT ON , ON THAT TV , IT ASK PIN NO , WHT I WILL DO
The codes to communicate with the TV has been tampered and so it must be reentered to set the remote to mesh up.
So check with the codes and reset,
http://www.xdiv.com/remotes/
http://www.hifi-remote.com/ofa/codes-tv.shtml
Jul 27, 2011 | Thomson 21DC320 21" TV
COD PIN FOR Tv-Thomson 21DC320, Tipe 507RG/ITC008
Sostituire la 24Wc08P con una nuova. Substitute 24WC08P with a new one. In this model it's very stressed and since it's a flash memory it has a limited number of writes. Ciao
Jul 07, 2010 | Thomson 21DC320 21" TV
Cannot connect laptop or ipod touch to Thompson TG585 wireless router. We only have pin and code numbers on the bottom of the router but nothing entered works
Forget the PIN that you need is the WEP which should also be on the barcode label.
Does your Thomson have a round button on the front with what looks like transmitter symbol?
If so, try pressing that first before you start typing in the WEP code.
Dec 20, 2009 | Computers & Internet
How can i reset my thomson tg585 v7 router as i have bought a new laptop with windows 7 and have forgotten my password???? many thanks.
You can reset Thomson TG585 by pressing the reset button located at the back of the modem for few seconds while the modem is power on. The LEDs at the front would blink and the modem will restart with factory defaults setting.
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Nov 08, 2009 | Thomson Computers & Internet
Thomson dti 652 lost pin code, what to do?
i for geate my thmson tv pin code
Sep 06, 2009 | Televison & Video
Thomson scenium doesn't start when we switch it on.
First, try to unplug and reset. Second, Remove back cover and check for shorted horizontal output transistor with ohmmeter. If shorted replace flyback. Next, carefully disconnect plug connectors from deflection pcb. No need to disconnect h.v. or screen leads. Remove from plastic frame and look at bottom (solder side) for cracks around pins of flyback transformer. Resolder all pins. Last, look for two or three bulging capacitors in power supply on same board and replace. Any of these things can cause a dead set. Good luck, Russmann.
Dec 11, 2008 | Thomson Televison & Video
Thomson TSR200 Satellite TV Receiver THOMSON Logo
46 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
