Question about Canon Office Equipment & Supplies
E-00000068 ir-7095 I continue to get a shutdown message with the 00000068 error code. I have used the air duster on the machine, have run a rather large project and am at the tail end of it.
SOURCE: Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Posted on Jan 12, 2009
  • 58 Answers
SOURCE: canon IR 7095
if you can not use the finisher and the machine says Functions limited
press additional function
press common settings and then scroll to find limited functions mode if its on press the off button press ok and turn off the machine and then back on
Posted on Aug 07, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
canontech
  • 1219 Answers
SOURCE: Canon IR 3100cn Copier Error Code E00002-12
E002 Insufficient temperature rise of the fixing unit
0002 The non-contact thermistor fails to
reach 70 deg C within 180 sec after
reaching 50 deg C.
Check on connection of the thermistor, Replace the
fixing unit
To recover from the error: In service mode ( * 2 8 * )
COPIER>FUNCTION>CLEAR >ERR
0003 The non-contact thermistor fails to
reach 100 deg C within 180 sec after
reaching 70 deg C.
0004 The non-contact thermistor fails to
reach 120 deg C within 180 sec after
reaching 100 deg C.
0005 The non-contact thermistor fails to
reach 140 deg C within 180 sec after
reaching 120 deg C.
0006 The non-contact thermistor fails to
reach 160 deg C within 180 sec after
reaching 140 deg C.
0007 The non-contact thermistor fails to
reach 180 deg C within 180 sec after
reaching 160 deg C.
0008 The non-contact thermistor fails to
reach standby temperature (normally
190 deg C) within 180 sec after reaching
180 deg C.
0101 The non-contact thermistor fails to
reach 120 deg C within 300 sec after
power-on.
0102 The non-contact thermistor fails to
190 deg C) within 300 sec after reaching
120 deg C.
Posted on Jun 16, 2010
azzoom_in10
SOURCE: Hi canon IR 6800 CN
canon ir 6800cn error code e000100-0002 solution
Posted on Nov 13, 2012
The canon IR 7095 image-runner that i need help with it has an error code E000578-8001
That error Indicates there is a malfunction in the finisher Unit . I am not sure if the problem is any of the delivery trays of a stapler error
May 17, 2017 | Canon Office Equipment & Supplies
C3852 error code
Fusing code I. the fusing unit is not warming up to the proper temp. Open the front to the right below where the cleaning clothes are kept there is a cover at about 45 degrees have to get on the ground and look at it there is hole small screwdriver to push the small switch to reset the machine for tha code it will not reset by powering off than on or closing the door.
Aug 10, 2014 | Konica Minolta bizhub C450P Laser Printer
ERROR CODE IN IR 7095 EOOO2- 0001
this error refer there is a problem in the fixing unit, check thermistor and clear that error from service mode
Apr 13, 2014 | Canon IR2870 COPIER FOR 220 VOLTS ONLY
Protection Message
Protection mode is a shutdown to protect the circuits on the amplifier. This will come on if the speaker wires are shorted or if their is a lot of DUST on the inside of your machine. On some machines, protection mode will come on if one of the speakers is open (breaks). What I would do is check the earphone jack on the tv. Put a headset in and see if that works. Last resort is purchase a can of air duster.
Jan 13, 2014 | LG HT356SD Region Code Free Home Theater...
Canon IR 7095, error code E000005-010
Hello to all
I have a client server ir Pass has forgotten his password and I reset.
how reinitialiser server S2 canon ir Pass?
Thank you for the help.
Dec 27, 2012 | Canon Imagepass S2 Fiery For Ir...
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Error code 07 on my Krups XP 7220 coffee machine
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Oct 26, 2009 | Krups Small Appliances Espresso Machine
I have a bixhub 600 with error code C-4707 can't
Write unit (Print Head/LASER) is bad, or lose connection to it.
Jul 31, 2009 | Konica Minolta Office Equipment & Supplies
Canon IR 7095
Jul 28, 2009 | Canon imageRUNNER 3570 Copier
27 people viewed this question
old marine
old marine
